Compression on my ls-v
Hey guys so I did a compression test today on my ls-v and I'm wondering if the numbers are good or if I should pull it and do a rebuild.
Specs on motor
Stock b18b1 bottom end
B16 head fully rebuilt with new springs and retainers, valves, and seals
(Haven't bought cams for it yet so I'm running stock gsr cams)
New head gasket, water pump, timing belt, and oil pump.
I've put about 1000 miles on it since I got the head rebuilt and after break in I did do a valve adjustment. But anytime I punch it I dump a ton of black smoke.
So here's pics of each cylinder when I did the test
Yes the car was at operating temp but I did not have WOT
Specs on motor
Head is new, are you sure it was put together correct? Rings may be bad (defective) or your cylinders are tempered. 150 is low, I had a 190k d16y8 with a valve lap job that had 210psi across on original rings. My rebuilt b18c with p73 pistons has 240 across. Pull that motor something isn't right.
I was just going to say not to be so hasty with the tear down. All the cylinders are within tolerance for compression variance. I would say it's ether your gauge or something with the procedure. As mentioned you will get a more accurate reading with the throttle fully open. Also ensure that the engine is warmed up this will also help give a more acurate pressure. You can do it cold though. ether way!
Then once you have done all 4 cylinders dry, try dropping a cap full of engine oil down into the cylinder through the spark plug hole. Then do the test again and post up the results.
eh, those numbers aare even but low. that about what my vitara motor put out and its compression was around 8:1. does it consume fluids? can you get access to a different comp. tester and/or do a leakdown test?
This doesnt make sense. 150psi with and without wide open throttle? I would say there is no problem considering they are all consistent to each other.
Specs on motor
Specs on motor
Very good for a 95 . A 95 integra came in the other day complained that his car is misfiring a frequently , did a compression test and found 120 , 126 , 40 , 90. At idle only 3 cyl are working .
Quick questions. Why did you do the head gasket? Did you buy a gasket kit? If you did did you change valve seals? Did you bring your head to the machine shop and had the valves replaced ?
Yea I talked to a buddy of mine who is a mechanic and he said my compression specs are still fine for now. And thanks for the help. quick question though, do I take all 4 spark plugs out at the same time and then start the test or just the plug from the cylinder I'm testing and then replace it and move on to the next one.
