P06 MAP sensor
Old Nov 30, 2013 | 06:12 AM
carlos8's Avatar
Default P06 MAP sensor
hi guys. I'm having a hard time finding my car Issue, After a lot of testing I find a MAP sensor low voltage between D17 + D21 = 4.0v map disconnected and 1.58v map connected.
The D17 + D21 should be 5.0v right?
I need help in what part of the ECU look for to repair it. What are the numbers location of the resistors and capacitors?
P06 chipped and vtec converted. Working excellent for 3 years suddenly start to bog and sputter when press the gas.
Old Dec 1, 2013 | 08:23 AM
carlos8's Avatar
Default Re: P06 MAP sensor
What numbers I need to look for the MAP sensor in the p06 board?
Old Dec 19, 2013 | 07:13 PM
Mad Fab Lab's Avatar
D17 = map sensor output, D19 = map sensor +5v supply
http://technet.ff-squad.com/wiring.obd1.htm
Old Dec 26, 2013 | 12:31 PM
VegasInvasion's Avatar
I'm Huge In Japan
I seriously doubt it's your ECU. Do these in order:
Test each wire from end to end for resistance, continuity, and ground fault.
Remove all other sensors and try the test again, see if the results change. If they do, diagnose other sensors & wires.
Check for corrosion, then replace or repair the pins on the ecu plugs and at the map sensor.
Check for corrosion or wire splints at the thermostat ground, remove the ground, clean it.
Check for corrosion or damage at the grounding/ power blocks in the engine harness.
Replace the map sensor.
Replace/repair the ECU.
Old Dec 26, 2013 | 01:15 PM
carlos8's Avatar
thanks, VegasInvasion.
I take my ECU to check professionally and test good, plus the guy run it in his car no problem.
change: MAP, ECT ,TPS and dizzy and the same.
The guy who test the ECU said there's be a problem in my harness, So I bought a new uncut one. I already extended and soldered the vtec PS and SOL, IAT and two wire IACV.
Saturday I'm going to install it and see what happen!!!
MatthewMenze
Engine Management and Tuning
May 1, 2014 01:24 PM
fenix4o9
14
Jan 30, 2013 12:39 AM
Veggie Man
Sep 25, 2012 02:49 PM
aldong
Oct 8, 2006 06:15 PM
