AEM EMS V1
Old Dec 19, 2013 | 07:55 PM
chingo's Avatar
Default AEM EMS V1
I recently purchased an AEM V1 for my 01 GSR. its serial #1001-0045, I already have the jumper harness for it to mate with the EMS. My issue is when I load up the stock cal. map the car wont start. Ive input everything in as far Inj, tps, map, ect. and still no start. every once in a while it would attempt to start then die. Does anyone have a decent base map for a stock GSR?
The vehicle is in working order, currently running on a P28 and it is my daily. Car runs flawless. Im just trying to get this AEM thing figured out and then get it to a tuner once the other motor and turbo go on. Thank you.
Old Dec 21, 2013 | 02:46 PM
xenocron's Avatar
Default Re: AEM EMS V1
Does it stat sync?
Old Dec 23, 2013 | 05:04 PM
chingo's Avatar
Stat sync? I havent noticed yet, but if it doesnt, what is the cause of that?
Old Dec 23, 2013 | 07:04 PM
turbohatch96y7's Avatar
How much did you pay for the v1? You can upgrade to the v2 pretty cheap.
List more details on the setup.
Map size
Injector size
Any boltons.
Old Dec 24, 2013 | 10:32 AM
chingo's Avatar
I pay less then what I would have bought an s300 if that helps. Not really interested in the V2. The setup im trying to get started is for a completely stock GSR, all it has is a short ram intake. Thank you for the reply.
Old Dec 24, 2013 | 11:11 AM
scmil95eg's Avatar
Sync timing, rinse, repeat.
Best way - turn injectors off, have friend crank car over while you hold timing light & watch timing marks. Once sync'd, turn injectors back on and fire it up.
adamrich33
Engine Management and Tuning
Mar 14, 2009 07:07 PM
B Funley
Mar 17, 2008 06:33 PM
11psiTurboSI
Apr 17, 2004 11:17 AM
metal-x
Apr 17, 2003 01:17 PM
