ECU toasted? fuel pump not priming car not turning on
Old 02-04-2014, 09:05 PM
Evos's Avatar
Default ECU toasted? fuel pump not priming car not turning on
Hello HT, I got a 1995 Acura Integra and yesterday i tried to start my car up and no go... i dident hear the fuel pump priming when i turned the key over so that was an immediate problem. I replaced the Main relay and still nothing. jumped the fuel pump at the main relay and it kicked on so with that still on i tried to turn the car over and nothing... I am running a JDM B18c(R) everything stock for the most part on a chipped p28. I'm thinking that its the ECU i checked the fuse for the ECU under the hood and it looked good even replaced it i believe it its a 15? Before i buy another p28 and get a chip made by xenocron anyone have any other possible ideas? ill post a pic up of the ECU in a bit doesn't look like any capacitors are blown or anything.
Old 02-04-2014, 09:11 PM
Evos's Avatar
Default Re: ECU toasted? fuel pump not priming car not turning on
Old 02-05-2014, 02:10 AM
7rrivera7's Avatar
This is a common issue with 20+ year old ECUs and is repairable. PM me if interested.
Old 02-10-2014, 12:49 PM
Evos's Avatar
Alrightttttt so got my chipped p06 from xenocron today, was pumped since this was the only thing that I could think of SO IT MUST be the solution right? No, car is still not running. ECU was not the problem....207 down the drain.. I tried to start my other civic with a b20 swap and i hear the main relay clicked but it also sounds like the ecu is clicking as well is this normal? I got back in my integra and it was not clicking. I really have no fkin idea what is wrong. Need help, please assist....soonish....
Old 02-10-2014, 06:38 PM
Retired Moderator
EsotericImage's Avatar
relay
Old 02-10-2014, 07:10 PM
ArniFPR's Avatar
check your grounds
Old 02-13-2014, 06:47 AM
Miguel613ekb18c's Avatar
Chech ecu fuse underhood they usually corrode, check if there's power between ELD and ecu fuse
Old 02-15-2014, 02:58 PM
I'm Huge In Japan
VegasInvasion's Avatar
x2 probably bad ground connection
Old 05-24-2019, 05:47 PM
Daniel Ra's Avatar
What is the r77 resistor size and info. On what it does please and what kind
Old 05-25-2019, 09:31 AM
7rrivera7's Avatar
Would have only been $50 but you ignored my offer and spent $207...
Old 11-10-2019, 08:21 PM
No Name's Avatar
i got an 08 FD with the same issue. Is it possiblr the fix is the same?
Old 11-11-2019, 06:42 PM
David Weiss's Avatar
first test for power at the fuel pump, if you get nothing there with the key on then test for voltage before and after the PGM-FI main relay, that should be everything you should need to do as long as it is a simple issue
Old 11-12-2019, 10:57 AM
No Name's Avatar
thank you. We did that. Except for the main relay test. Car is sitting at the dealership now. Dashboard diagnostic gave me an eror 1 and four different readers can't get a signal off of it.
Evos
02-10-2014 06:12 PM
jdmAccord210
Engine Management and Tuning
10-22-2013 11:22 AM
Markalark
09-22-2013 03:32 PM
no_rice_please
10-12-2009 09:36 PM
DarkBB4
09-13-2007 04:24 AM
Quick Reply: ECU toasted? fuel pump not priming car not turning on
