P28 MAP sensor location
Old Feb 2, 2014 | 02:43 AM
carlos8's Avatar
Default P28 MAP sensor location
hi guys, I'm having problems with my ECU sending low voltage at MAP sensor. Need help to find the location of the map hardware on the board to repair it if is fixable.
If anybody can post the numbers of MAP location, this will be very helpful.
Thanks in advance
Carlos
Old Feb 2, 2014 | 06:09 AM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
Default Re: P28 MAP sensor location
What exactly do you mean by sending low voltage? Do you mean you aren't getting +5v at the MAP sensor or that you are getting low reading from the MAP sensor at the ECU?
Old Feb 2, 2014 | 09:09 AM
carlos8's Avatar
The MAP plug disconnected isn't getting 5v in the red/green with the switch on and body ground.
according to the FSM you need to get 5v on both sides of the plug with switch on and body ground or using the center wire as ground. I'm getting 5v on Yell/red but 3.52v on red/green.
Click the image to open in full size.
__________________
Old Feb 2, 2014 | 12:38 PM
carlos8's Avatar
This is the test I'm performing:
http://img183.imageshack.us/img183/3968/81870256ab2.jpg
http://i288.photobucket.com/albums/l...Picture3-1.png
http://i288.photobucket.com/albums/l...e/Picture4.png
Old Feb 3, 2014 | 09:35 AM
carlos8's Avatar
Anybody!!! can tell me the location of the MAP sensor on the board?
Old Feb 3, 2014 | 07:00 PM
92cxturbo's Avatar
Your best bet is to try a different ecu, and verify that the issue is the ecu. Xencron may be able to fix it, if in fact the ecu is bad. It may be more cost effective to just replace the ecu. What ecu are you using now?
Old Feb 3, 2014 | 11:02 PM
carlos8's Avatar
I'm using a P06 chipped and vtec converted.
My best bet it's to try another ECU, but not have any friend with obd1 ECU.
Xenocron was my first tough but cost effective is better buy a new one for $140.00 since I'm in P.R.
carlos8
Engine Management and Tuning
Dec 26, 2013 01:15 PM
Charlie Moua
Apr 18, 2012 07:56 PM
aldong
Oct 8, 2006 06:15 PM
Sketch_hs
Jun 22, 2004 08:12 AM
