s300 issue
Old Feb 4, 2014 | 01:54 PM
avotegra's Avatar
Default s300 issue
S300 issue with ect not auto updating in realtime mode. I have to turn key off and on to update ect. I domt know if that is normal.
Old Feb 4, 2014 | 02:07 PM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
Default Re: s300 issue
Obviously it is not normal. Are you positive that you have a real S300 and not a fake one?
Old Feb 4, 2014 | 02:29 PM
Muckman's Avatar
Moderator in Chief
Moving this to EM&T
Old Feb 4, 2014 | 06:48 PM
avotegra's Avatar
Is there really a fake s300 out there...really? Will my problem is that the ect temp reading is always going up and stay there. When I am driving it should go back down or when the fan come on but it's not. For it to go down to, I have to turn key off and on to cycle ecu and s300 to get the right temp to show up again on the display on s300. I don't know if s300 is suppose to do that.
Old Feb 4, 2014 | 07:09 PM
mtber's Avatar
Yes there was fake counterfeit s300s made read: http://www.hondata.com/s300_counterfeit.html
Concerning your issue, make sure you are using the original USB cable provided with the system that has a noise filter on it.
Old Feb 5, 2014 | 04:46 AM
Muckman's Avatar
Moderator in Chief
Record an internal datalog and see if the ECT is acting up there too. That will isolate the Ecu from communication or software issues with the laptop.
Old Feb 11, 2014 | 03:11 PM
VegasInvasion's Avatar
I'm Huge In Japan
process of elimination. test continuity, new calibration, new ecu, new sensor, replace S300.
Old Feb 13, 2014 | 05:51 PM
RACEPAK's Avatar
i had the same issue with my s300's ! ! !
temp goes up to 97c but the car is actualy 90-91c if i turned the car off and on fast it would read 91c again and go up to 97c again,
https://honda-tech.com/forums/engine-management-tuning-124/hondata-s300-ect-reading-vs-other-softwares-3141707/
http://www.d-series.org/forums/engin...softwares.html
i ended up selling one of my s300's
Old Feb 23, 2014 | 11:40 AM
RACEPAK's Avatar
no one?
Old Feb 27, 2014 | 02:41 PM
Spunkster's Avatar
Just tested this in my own car and it's working normally. Temp goes down once fans come on, and ECU is controlling fans and they shut off properly.
Old Mar 11, 2014 | 02:23 PM
I'm Huge In Japan
Originally Posted by RACEPAK
no one?
civicsored
Honda Civic (2001 - 2005)
Jan 13, 2014 04:04 PM
b_serious
Dec 1, 2005 01:04 PM
DrewDown
Aug 23, 2005 12:56 PM
bbarbulo
Mar 16, 2005 08:31 AM
