J12 Question (back to stock)
Old Apr 13, 2014 | 07:03 AM
carlos8's Avatar
Default J12 Question (back to stock)
hi guys, Working on my cousin car, and had little problems with the turbo, so he order a new one.
Now, I put stock injectors, map, header and put the j1 switch to off. So back to stock p30.
Question is: Do I have to resold the J12 or she works like this?
Old Apr 13, 2014 | 07:23 AM
mtber's Avatar
Default Re: J12 Question (back to stock)
You don't have to touch j12
Old Apr 13, 2014 | 08:32 AM
carlos8's Avatar
Thanks mtber!!!!
Old Apr 13, 2014 | 11:36 AM
carlos8's Avatar
mtber, having a issue, when disconnect the MAP sensor, the CEL not pop ON and not want to rev., connect it and no rev it chokes.
Can you give me a hint?
Old Apr 13, 2014 | 08:06 PM
mtber's Avatar
Make sure you don't have the TPS and Map sensor plugs mixed up.
The tps plug will have a red middle signal wire on it.
Old Apr 14, 2014 | 05:27 AM
98vtec's Avatar
moderator emeritus
all j12 does is lock and unlock datalogging capability. it wont keep the ecu from going through its normal routine
Old Apr 15, 2014 | 12:31 PM
VegasInvasion's Avatar
I'm Huge In Japan
codes don't always pop up right away, sometimes you have to drive it a little for the ECU to process an error. Also make sure the engine light isn't burned out or been removed, I've been seeing that far too often lately.
jdmboostedhatch
Jan 22, 2009 11:50 AM
jrs2ksi
Oct 22, 2006 02:48 PM
Si Shane
Apr 9, 2005 08:23 AM
MugenFlaredCRX
Jan 11, 2005 08:54 PM
