Demon moates for Neptune
Old Mar 13, 2014 | 11:35 PM
walo's Avatar
Default Demon moates for Neptune
My demon is dead. I was perfectly installed. I was just making some idle tuning and suddenly neptune crashes. I restart the software but this time it couldn't connect to demon. When I open the ECU I realize the demon has no LEDs on, demo is dead.
I will get a new one, but I want to know is this is a common issue or I had very bad luck.
Old Mar 14, 2014 | 06:40 AM
HRTuning's Avatar
Default Re: Demon moates for Neptune
Moates released Demon Firmware 1.9 last year to fix a very random issue where the unit could overflow the buffer, corrupt RAM, and get stuck on next power up. This would not happen to everyone (<1%). If you did the update and still had the unit die then you simply had bad luck. If you didn't do the update you likely weren't running the latest software either, since it would have told you there was an update available.
Old Mar 14, 2014 | 06:57 AM
walo's Avatar
I updated firmware as soon as it has released.
Which is more weird, is that the same thing happend to a friends o mine some time ago.
Old Mar 14, 2014 | 06:59 AM
HRTuning's Avatar
If you were running 1.9 then that wasn't the issue.
Old Mar 14, 2014 | 10:59 AM
averyvm's Avatar
Sorry to hear about that. Are the people at Moates gonna help you and repair it or are you going to have to buy a new one?
Old Mar 14, 2014 | 11:09 AM
walo's Avatar
Yes they will, but that's not my concern.
I am pretty sure that demon died because a data transmition problem, and if thats the case, it can happen again. I was resetting the demon when this happend. Maybe like a firmware update, if something go bad during this process, it will die.
I am very far from US, so RMA is expensive and take a lot of time. I hope this don't happen again.
Old Mar 14, 2014 | 02:02 PM
HRTuning's Avatar
Resetting the Demon could have sealed the deal if it was already in a failing state. Let Moates know this.
Old Mar 14, 2014 | 02:12 PM
walo's Avatar
Resetting the demon i mean using the neptune software.
Menu -> Emulartor -> Reset demon
Old Mar 15, 2014 | 09:31 PM
HRTuning's Avatar
Yes, it wouldn't matter what software you reset it with. If it was failing engaging the reset could have sealed the deal.
jdmark1
Dec 17, 2017 12:38 PM
Turboshooter44
Apr 17, 2015 09:22 PM
delguiner
Jul 20, 2004 02:32 PM
