solid cel good ecu donno
Old Feb 22, 2014 | 05:28 PM
raverx3m's Avatar
Default solid cel good ecu donno
so im temporarily using my p30 ecu from del sol OBD1
its chipped and was used wit neptune and crome on my other car for few years.
ecu is 100% good i had it in my del sol and had no codes with chip or without.
i put a b16 in the integra fro now and all the sensors are connected everything is adjusted etc. engine runs good and idles good
in diagnostic mode its a solid cel and regular running is solid cel. ecu reset twice same thing.
engine harness looks good
thermostat ground is there
obd2b>obd1 ecu jumper harness looks ok too i didnt see anything wrong
just looking for more ideas what to check i gotta take it to emissions on monday
CEL needs to be off(the right way not bulb tricks)
Old Feb 23, 2014 | 10:01 AM
HRTuning's Avatar
Default Re: solid cel good ecu donno
Did you remove J1 and try it stock?
Old Feb 23, 2014 | 02:01 PM
raverx3m's Avatar
Its on stock map now since its a b16a2
All sensors are connected
Old Feb 23, 2014 | 03:31 PM
blackeg's Avatar
well...something similar to this happened to me a few months ago. turns out the thermostat ground wire was bad INSIDE the loom not at the connection where it bolts on. try running a wire from the harness where it goes into the jumper harness to a metal ground (i just wound up bolting it to the dashboard bracket)
its a longshot, but it was my issue when i got a solid cel with known good ecu's
Old Feb 23, 2014 | 04:16 PM
GagnarTheUnruly's Avatar
O2 heater?
Old Feb 23, 2014 | 05:12 PM
raverx3m's Avatar
wouldnt thermostat wire affect the main relay. because thats where it gets the ground from as well.
it wont work properly at all if thermostat ground is bad.
but everything works good just solid cel.
im just gonna hook up the neptune ecu with rtp to check the sensor output
Old Feb 23, 2014 | 08:41 PM
raverx3m's Avatar
found the problem
it was O2 heater element throwing the code
and then i enabled knock sensor and it was throwing a code for that for some reason.
its a good working knock sensor also and stock engine with P30 ecu with working knock board.
why would that happen?
Old Feb 24, 2014 | 03:07 AM
Freemananana's Avatar
I know the thermostat housing ground will give you a solid CEL. But it seems you found the issue.
The knock sensor has always given me issues on chipped ECUs. I usually disable it. But most of the time I'm using a board without the knock board so it only makes sense to disable it.
Old Feb 24, 2014 | 09:44 PM
raverx3m's Avatar
oh and the knock sensor i had a tard moment
i plugged in a p28 ecu with neptune and enabled the knock sensor lol
failed emissions pretty badly today
can it be bad O2 sensor?
is a solid cel and O2 sensor heater cel a sign of bad sensor or an ecu/wiring issue
Old Feb 25, 2014 | 05:36 PM
raverx3m's Avatar
ok so i tried different way today
got a p2t ecu from civic si
got a different used sensor that measured good
plug it in no code, let it warm up no code
took it to about 5-6k rpm it popped a p0170 code( fuel tri malfunction bank 1)
then after about 5 min of idling the O2 sensor heater code came back up
and kept coming back after clearing...
so with a solid cel from obd1 p30 ecu to sensor heater with p2t ecu is there something else i should check with wiring besides O2 sensor?
i checked the thermostat ground already and cleaned it
Old Feb 26, 2014 | 09:48 PM
raverx3m's Avatar
well sure as hell it was something stupid just like always my luck
the heater element pin backed out but because it was so dirty from previous deuchebag owner(s) i didnt see it.
no codes so far wtf all this time wasted
big **** you goes to previous owners who didnt maintain this for ****
wicked_gk
12
Sep 20, 2012 01:12 PM
kcvi3tstyl3
Apr 20, 2009 06:17 PM
drumminforev
19
Oct 6, 2006 12:12 AM
1slowcrx
Jun 16, 2004 01:21 PM
Hondasaurs
Apr 25, 2003 09:00 AM
