S300 LAUNCH CONTROLL
Old Dec 16, 2013 | 11:32 AM
vanner232's Avatar
Icon2 S300 LAUNCH CONTROLL
anyone have actual experience setting up l/c on the s300???
Old Dec 16, 2013 | 12:58 PM
SpoonMotorSport's Avatar
Default Re: S300 LAUNCH CONTROLL
Hondata s300 doesnt support ignition cut only its going to be either fuel cut or fuel and ignition cut both
Old Dec 16, 2013 | 08:30 PM
motoxxxman's Avatar
yes.
what is your question about it?
Old Dec 17, 2013 | 08:27 AM
vanner232's Avatar
just wondering where to start... gonna mess with it today a bit. from what iv read -20 /-25 with 0-15% fuel gain is an ideal starting point? just want to make sure never messed with it. i would imagine i would want atleast 7-8lbs of boost. the car has never been tuned this high. its sitting at 398 -no traction what sooo everr
Old Dec 23, 2013 | 11:02 AM
motoxxxman's Avatar
I usually start in the -15/-20 with +10%/+15%fuel area.
the amount of boost you can build with launch control is much different than the amount of boost you WANT to build during launch. every setup will be different, and will like different settings, different rpms, and different pressures.
smaller turbos and/or higher compression will typically respond better to lower pressures during launch, because they're capable of faster spool and higher power per psi. launch rpm also largely depends on your torque curve, and your tranny's gearing, and the level of traction you have at that specific moment (track, tire, and temp dependent).
IE: my buddy's car is only capable of building 6psi at 6k, and it's still not enough for a nice solid launch. his turbo is simply too frickin big, and it's a low comp motor.
my car is capable of building 30psi at 6k, but my best launches have always been at part throttle and in VACUUM at 5500, around 10"/hg of vacuum, because I run higher compression and a smaller turbo. my spool is almost instant when over 4k in ANY gear, whereas my buddy's car can barely even spool at all in 1st and 2nd gear because of how huge his turbo is and the engine is not loaded up enough for long enough in those gears for the turbo to really get spinning fast enough to do anything lol.
Old Dec 26, 2013 | 07:28 AM
Charisma's Avatar
Start with the bold and go from there. You'll need to do some testing to see what the car likes, obviously. One car may leave with a 1.5 60' while the next May pull a 1.7 based on the same launch control. What I mean here is, there is no end-all answer I or we can give you.
Old Jan 2, 2014 | 08:44 AM
vanner232's Avatar
all i needed was a starting point guys.. i do have a fairly big turbo..its very hard to get spooling but i'm making around 6psi right meow at what seems to be 6500rpm..lol going to mess with it somemore when it dries up a little. thanks for the info.
Old Jan 2, 2014 | 09:18 AM
motoxxxman's Avatar
6psi right meow
MEOW!
R.A.T.
Aug 15, 2011 12:11 PM
mike93eh2
Nov 16, 2006 08:15 AM
_k20a2_
Oct 15, 2006 05:09 AM
VTcivicEG
Oct 26, 2004 06:00 PM
EH2LS
Jun 5, 2003 05:53 PM
