obd0 to 0bd1 question.
Old Mar 7, 2014 | 12:54 PM
Greyknight1138's Avatar
Default obd0 to 0bd1 question.
Hello guys I recently purchased a 1992 hatch with a b18a1 swap. I have done a lot to the motor and was going to have the ecu work done when a friend offered me his Gude Performance Ecu out of his 91 integra. Will a simple jumper harness allow this ecu to run in my 92 car just fine? Or is there more I will need.
Old Mar 10, 2014 | 04:44 AM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
Default Re: obd0 to 0bd1 question.
Unless he was converted to OBD-1 that is a OBD-0 ECU and you would be doing yourself a HUGE disservice by trying to step down to OBD-0.
Old Mar 10, 2014 | 05:00 AM
Freemananana's Avatar
Yes. This is true. Also, OP, I wouldn't trust a performance ECU. Optimized fuel tables are pretty specific to each set up. It's sort of like the generic chips you see. Unless Gude is the exception.
Auby
Mar 8, 2009 02:32 PM
jdmekrobot
Sep 4, 2006 09:40 AM
FOMULA91
Jul 18, 2005 01:31 AM
SadisticRacing
Nov 13, 2003 08:53 PM
