Step retard on TurboEdit
Old Apr 12, 2014 | 09:30 AM
Ca90dxB20B's Avatar
Default Step retard on TurboEdit
Hey guys ! I recently put a B20b in my 90 dx hatch , my car is still OBD0 with a xenocron chipped ECU . I tuned the fuel tables with TurboEdit and I have the cruising AFRs at 14.5 , 13.0 when entering boost and a consistent 12.0 @10 psi . I'm running a 60-1 turbo , cast log mani , stock ignition with ngk bk7re plugs gapped at .026 , 450cc injectors and a gsr fuel pump (will be upgraded to a walbro next week) . I use a innovate wideband for fuel tuning but I do not have an egt gauge unfortunately . Now .. On to my question. I'm using the step retard option on TE set at the recommended starting point of -.25 , I have no detonation but it feels lacking in power . Should I take away from this number or add to this number to get more power , and at what increments ? Will changing this step retard number automatically adjust each individual psi accordingly to retard more as you get to higher boost levels ? Thanks ahead of time !!!! Casey
Old Apr 12, 2014 | 10:49 AM
VegasInvasion's Avatar
I'm Huge In Japan
Default Re: Step retard on TurboEdit
there's no easy way to tune ignition. there's definitely no safe way to estimate ignition either. in my experience it's likely that you could add a few degrees to the entire map and it'd be fine, but the only way to tell if you're making safe power is to graph the results. the manual in my signature is for Crome, but the process is the same for TE.
Old Apr 12, 2014 | 11:51 AM
Ca90dxB20B's Avatar
Ok so maybe I should switch it to linear then add one number at a time to see how it does ?
Old Apr 15, 2014 | 12:33 PM
I'm Huge In Japan
never adjust the linear ignition base. you should read my manual.
Old Apr 21, 2014 | 01:00 PM
Ca94cr250's Avatar
Do you have a link ? Anything that would be helpful would be greatly appreciated
Old Apr 21, 2014 | 01:21 PM
Muckman's Avatar
Moderator in Chief
Its in his signature
bvillarreal
Nov 21, 2012 02:43 PM
R.A.T.
Aug 15, 2011 12:11 PM
dirtySOHC's
Jun 21, 2003 11:00 PM
KJ
Jul 2, 2001 07:54 AM
Evil DOHC
Jun 15, 2001 05:28 AM
