Help k20a2
Old Mar 6, 2014 | 02:56 PM
dbb95ex's Avatar
Default mods delete post fixed issue
delete
Old Mar 6, 2014 | 07:45 PM
Muckman's Avatar
Moderator in Chief
Default Re: Help k20a2
I don't see your TPS or MAP fluctuate with RPM.
Old Mar 7, 2014 | 01:03 PM
dbb95ex's Avatar
The map does move but I don't know how to zoom in to show it. As for the tps you are correct but I don't know why. I'm new to using kpro, I looked back at an older datalog from before it started acting up as you can see, totally different.
Old Mar 7, 2014 | 02:34 PM
Muckman's Avatar
Moderator in Chief
Make sure you selected the right MAP sensor in the calibration. It looks like the MAP is still flat lined. That def is a problem if the ECU cannot see the manifold pressure. Your AFR is flatlined too. All kinda of setup issues. Start with the helpfile! lol
carlos8
36
May 4, 2014 05:42 AM
cyanid3
Engine Management and Tuning
10
Nov 9, 2009 10:12 AM
ivt-t
Aug 22, 2005 11:06 AM
ek9 ferio
May 31, 2005 07:49 PM
