Difference between injector plug and pigtail OHM'S
Old Mar 25, 2014 | 05:19 AM
carlos8's Avatar
Default Difference between injector plug and pigtail OHM'S
hi, Try to find a solid answer, There's should be a difference in ohm's when test an injector directly in the plug and with the pigtail connected?
Injector 13.2 ohm's
Injector with pigtail 50-55 ohm's
https://honda-tech.com/attachment.ph...1&d=1395749962
Injector connected to pigtail measuring in Yellow plug.
Old Mar 25, 2014 | 05:55 AM
Muckman's Avatar
Moderator in Chief
Default Re: Difference between injector plug and pigtail OHM'S
There shouldn't be any significant difference unless there is a wiring issue with the pigtail (ie bad terminal)
Measure the resistance of just the pigtail. It should be next to zero.
Old Mar 25, 2014 | 08:23 AM
carlos8's Avatar
Wow, this is really very interesting.
I have two of them in my hands right now: Voltmeter set to resistance the first not even beep.
1- red wire=060, black wire= 023
2- red wire=011, black wire=010
https://encrypted-tbn1.gstatic.com/i...xeN4rWIwze7R3Q
This the ones I use. They come as a package with my Precision injectors.
Old Mar 25, 2014 | 09:23 AM
Muckman's Avatar
Moderator in Chief
#1 looks like it was crimped improperly. I bet if you take apart the connector you will find the terminal barely hanging on.
Fuel Injector Clinic
Performance
Nov 29, 2013 08:05 AM
Arthas
Mar 3, 2010 05:08 PM
Cole89ef
Feb 12, 2009 06:50 PM
2ndGenREX
Jan 14, 2007 07:29 PM
jdmcivicferio
May 6, 2003 10:53 PM
