s300 launch conrrol problrm
Old Dec 1, 2013 | 04:12 PM
juba_x's Avatar
Default s300 launch conrrol problrm
I go to set up 2step and the car won't start again its a p28 s300 v1 running a lsv tried to set it up running and just dies when uploaded
Old Dec 2, 2013 | 11:26 AM
motoxxxman's Avatar
Default Re: s300 launch conrrol problrm
upload it with the ignition on but the engine off. then try starting it.
are you absolutely 100% sure you uploaded the correct map? are you 100% sure nothing else got changed by accident?
Old Dec 7, 2013 | 02:43 PM
juba_x's Avatar
Yes it was the right map we just got done street tuning it. We went to let the car cool down a bit so the car was off with key on and wouldn't start
Old Dec 8, 2013 | 09:43 PM
SwappedTURBOegg's Avatar
make sure software is up to date erase ecu then re upload.
Old Dec 10, 2013 | 02:06 PM
VegasInvasion's Avatar
I'm Huge In Japan
if it continues try using a new base and import all the settings from the old map. the calibration may be corrupted.
blkdoutteg
Engine Management and Tuning
14
May 5, 2019 11:05 AM
RACEPAK
Apr 29, 2016 07:20 PM
donperry
14
Aug 19, 2015 05:45 PM
Civicman86
Mar 24, 2007 01:15 PM
