Aem wbo2 wire to ecu
Old Mar 16, 2014 | 06:14 PM
2000ekd16's Avatar
Default Aem wbo2 wire to ecu
Ok so I have a aem wbo2 in place of my stock o2. In saying that I have no o2 sensor hooked up to ecu. Ecu is p28 chipped with crome. I wanna know if I have to get another bung to put my stock o2 sensor on or can I run the white output wire to wire harness/ecu.
Old Mar 22, 2014 | 07:15 AM
Muckman's Avatar
Moderator in Chief
Default Re: Aem wbo2 wire to ecu
Manual by VegasInvasion. Check out page 38.
http://www.gravityimports.com/CROME_v1.6.x_Manual.pdf
Old Mar 25, 2014 | 06:26 PM
VegasInvasion's Avatar
I'm Huge In Japan
^ thank you sir
However, the AEM WB "gauge" only has a 0-5v wideband output, which is only compatible with the Crome Gold rom and needs to be correctly programmed (see manual).
Otherwise you do need a NBO2 or a wideband controller that has a simulated NBO2 output if you wish to run closed loop. On the other hand, you shouldn't need closed loop if it's tuned well enough...
Old Mar 25, 2014 | 06:46 PM
Muckman's Avatar
Moderator in Chief
I didn't know you cant even use a wideband without the gold version. Boo
Old Mar 25, 2014 | 09:00 PM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
You are wrong if it is a 30-4100 which is the most common one due to its price point. See page number 10:
https://www.google.com/url?sa=t&sour...-T5gn3VvauT1WQ
I knew because I own one.
Old Mar 26, 2014 | 07:56 AM
Rtype16's Avatar
Yes you can change the output of the gauge to other settings so it doesn't use the 0-5v output calibration.
Old Mar 26, 2014 | 10:27 AM
Muckman's Avatar
Moderator in Chief
Yes but you still cant tune off the 1v output can you?
You have this awful, non linear resolution.
Old Mar 27, 2014 | 08:08 AM
Rtype16's Avatar
Correct however it is giving you a linear output. However being the spread is only 1 volt your resolution is going to be pretty small.
Old Mar 27, 2014 | 09:21 AM
Muckman's Avatar
Moderator in Chief
You consider this linear?
Old Mar 27, 2014 | 11:23 AM
DO IT ON ALL FOURS
I don't see what the fuss is about. You don't HAVE TO have wideband datalogged to tune a car. Although, even though I haven't had CROME Pro in a while (since I have Dealer and just use Gold) I could have sworn you could select from a few widebands you just couldn't edit your own tables.
Old Mar 27, 2014 | 01:13 PM
Rtype16's Avatar
Sorry I was looking at the wrong output graph, but that isn't the output either. You can download the instructions in the link above that has the specific voltage to AFR output.
Old Mar 28, 2014 | 01:29 PM
98vtec's Avatar
moderator emeritus
I have not done tuning without an ability to log afr since 2003. Logging AFR in a plot takes all the wasted time and basically guessing out of the equation.
upgrade to a nicer software/hardware and you wont have this problem.
Old Mar 31, 2014 | 11:30 AM
I'm Huge In Japan
If you have a load-bearing dyno and about 3 hours you can get the fuel maps really close even without datalogging. I recently had a Nissan with a faulty OBD port on an SAFC that I had to tune freehand... Sucked.
Muckman, you can tune using a wideband input with P30, but you can't program a closed loop wideband scale without the gold rom.
Treyschls
Dec 11, 2014 07:49 PM
crxb16a90
Engine Management and Tuning
Oct 25, 2010 12:03 PM
A2gt35r
11
Feb 21, 2009 03:05 PM
sanfriz
Mar 26, 2006 11:06 PM
zerovandez
10
Feb 9, 2006 11:36 PM
