chipped ECU help!!
Old Dec 5, 2013 | 01:03 PM
carlos8's Avatar
Default chipped ECU help!!
hi, I'm having a lot of problems with my civic ls vtec turbo, no CEL sputtering and dying when press the gas.
I changed all the ignition system: dizzy, wires and plugs.
TPS, ECT and MAP sensors. (all new)
Check mech. Timing an is on spot and set ignition timing by gun.
Fuel press is steady and raise when try to rev.
Then start to measure the outputs and inputs and find some discrepancies in voltage. i.e. MAP plug disconnected d17+d21=3.89v should be 5.0v
TPS .45v at sensor plug and .39v at ECU plug.
I'm tired of throw money with out know exactly what is. Somebody tell me that with the 3.98v read at d17 means my ECU is fried, I want a second opinion to buy another one. I just want to solve this.
Any help will be appreciate.
Old Dec 5, 2013 | 05:39 PM
b20bFourDoorCivicLX's Avatar
Default Re: chipped ECU help!!
no dyno?
Old Dec 6, 2013 | 01:35 AM
carlos8's Avatar
Yes, the car was tuned and working perfect.
This start 2 weeks ago.
Old Dec 6, 2013 | 08:27 AM
7rrivera7's Avatar
Carlos, we will get to the bottom of this during the weekend. You are in good hands with EFI Logic!
Old Dec 6, 2013 | 10:39 AM
carlos8's Avatar
Thanks, I'll call you tomorrow morning.
Saludos.
carlos8
Dec 4, 2013 02:55 PM
nightscream
Engine Management and Tuning
Sep 18, 2011 12:27 PM
b16DooD
Jul 14, 2011 07:47 AM
90integ
Jun 7, 2011 10:15 AM
Atech77
Feb 15, 2010 08:17 PM
