Datalogging TPS Issue
Old Feb 26, 2014 | 02:51 PM
Freemananana's Avatar
Default Datalogging TPS Issue
So I have an OBD1 ECU (P28) hooked up with a Neptune RTP Demon Board. Everything is functioning. But I have a question.
The TPS is at "-7" at idle according to my logs. Is that a calibration issue? Do I need to reset my TPS? I have had some minor issues with my idle on cold start, but nothing to write home about. Just the usually bouncing idle that I had attested to a dirty IACV or FITV that I haven't fixed. Could that be the TPS though?
Thanks. I know NepTune has a forum, but it's not very active.
Old Feb 26, 2014 | 04:08 PM
spAdam's Avatar
Loved
Community Favorite
Default Re: Datalogging TPS Issue
There is a TPS calibration in the preferences tab.
Old Feb 26, 2014 | 04:18 PM
Oh. Okay. I 'knew' that I suppose. I thought my stock TPS could just be out of wack.
Old Feb 26, 2014 | 05:23 PM
spAdam's Avatar
Loved
Community Favorite
Nominal voltage is .45-4.5V for 0-100%, respectively. There is a tolerance in the service manual but I can't remember what it is off the top of my head.
Old Feb 26, 2014 | 05:36 PM
HRTuning's Avatar
The NepTune forum is checked day in and day out. It's not highly "active" because there's not a lot of issues with the system... posts as recent as 4 days ago. Next time post there or email in for quicker help.
Use IACV duty cycle to adjust your idle. If your TPS is way out of spec think about adjusting it appropriately, but that's not the cause.
Old Feb 27, 2014 | 02:44 AM
Thanks. I know this isn't a NepTune issue. It's just a my car issue. I saw the -7 and thought my TPS could have been poorly adjusted after 25 years. I just wanted to rule out my TPS before I started changing settings.
Old Feb 27, 2014 | 06:05 AM
HRTuning's Avatar
If there's not an actual issue with the IACV the duty cycle adjustment should be able to clear it up. If you still have issues then try cleaning it out. If it still isn't fixed give a shout back.
Old Feb 27, 2014 | 06:28 AM
Absolutely. I will try and be more active on the NepTune forum. I am sure there is a ton of specific information. I also need to watch the videos again. I am always forgetting short cuts and stuff.
Old Feb 27, 2014 | 10:12 AM
HRTuning's Avatar
There's a quick keys list in the help menu, too.
.hawaii
Nov 13, 2009 05:10 PM
SmogTech01
May 26, 2007 11:31 PM
accord9t3
Nov 15, 2004 09:47 AM
b16a1civichb
Jun 4, 2003 04:24 PM
