Trouble setting timing on d16!!
Old Mar 9, 2014 | 06:03 PM
TruckeeEG's Avatar
Default Trouble setting timing on d16!!
So im trying to set my timing, I jump the connector, then when I'm trying to set my timing and idle one is way off. I need to be at- idle 670 +- 50, timing 16+- 2 but wen I set timing, idle is way too high about the 1000 range and when I set idle, timing is way too low about 5!!! I'm not to sure what the next move should b, anything helps, thanks!!
Old Mar 10, 2014 | 04:40 AM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
Default Re: Trouble setting timing on d16!!
You need to follow the instructions on how to actually set ignition timing. That is not how you do it... Purchase a repair manual and it will guide you step by step.
Old Mar 10, 2014 | 03:28 PM
TruckeeEG's Avatar
What do u mean that's not how I do it??
Old Mar 10, 2014 | 05:48 PM
DO IT ON ALL FOURS
I know you are begging to be spoon fed but you forgot about the part of disconnecting the IACV to bring the idle down. Set idle, set timing, check idle, and if idle needs to be adjusted recheck timing. Rinse and repeat if necessary. Also, using a factory gauge cluster is not recommended at all. They are usually off a couple hundred RPM. It is best to use a digital multimeter.
Old Mar 11, 2014 | 02:49 AM
Freemananana's Avatar
Google would have solved this whole thing man. Keyboard warriors and long time HT members never get along.
He actually did answer your question though. Just take the good and the bad and be thankful.
Unplug the IACV, adjust the TB screw for the idle, set at 750 with your multimeter (or 800~) Set timing at the dizzy by rotating to 16 degrees via timing light, done.
Old Mar 11, 2014 | 01:04 PM
Muckman's Avatar
Moderator in Chief
All the OP saw was the first sentence. He actually answered your question correctly.
Old Mar 29, 2014 | 10:16 AM
video_voide's Avatar
Care to elaborate, what exactly is being probed here?
Old Mar 31, 2014 | 12:00 PM
VegasInvasion's Avatar
I'm Huge In Japan
How do people own cars and not own a repair manual? I'm... flabbergasted.
Also I'm sorry for bumping this thread, I couldn't contain myself.
Old Mar 31, 2014 | 12:27 PM
DO IT ON ALL FOURS
I blame the Internet.
xxxmikenicexxx
Oct 11, 2009 01:03 PM
rtiadnoh
Feb 24, 2004 04:44 PM
keebler65
Oct 2, 2003 09:14 PM
Civic89
Aug 8, 2002 01:48 PM
non-VTEC
Jan 27, 2002 12:15 PM
