[Help Please]
Old Nov 20, 2013 | 06:28 AM
Dayvid's Avatar
Default [Help Please]
Hey guys, I have an idea, wondering if I can get some input and feedback.
Right now I'm running an Un-Tuned all motor 1997 Acura Integra.
The car has a B16A 81mm bored and honed block with a b18c1 head.
The engine has Type R cams and Type R pistons.
Right now the car is running a p72 A02 ECU (Integra GSR obd2).
I was wondering, since the car is running closer to OEM Type R than It is OEM GSR, if it would be a smart decision to put in a Type R ECU (P73 obd2).
The compression ratios and everything practically match, so..
Only reason I ask is because it's my daily, wondering if the Type R ECU would be better for the car running un-tuned than the current GSR ECU.
Input / feedback?
Thanks!
Old Nov 20, 2013 | 10:42 AM
AaronEJ's Avatar
Default Re: [Help Please]
That or that is not right for this type of engine
you should get a tunable ecu and get a right tune,
there is a lot to gain with a good tune on this kind of setups.
Old Nov 20, 2013 | 12:29 PM
VegasInvasion's Avatar
I'm Huge In Japan
if you didn't have the option of a chiped ecu, the P73 would be more ideal, but the P72 will still run it decently as long as the knock sensor is hooked up.
but obviously a tuned ECU will run it much better than either stock ECU.
Jdmbryan
Jul 20, 2012 05:40 AM
AbsolutGentry
Feb 11, 2008 05:10 PM
hlee5363
May 22, 2006 02:38 PM
skata89
Mar 12, 2006 08:21 AM
Slow_import
Oct 6, 2005 10:34 PM
