Suggestions on boost table problem.
Old Mar 9, 2014 | 09:40 AM
30psi_gst's Avatar
Default Suggestions on boost table problem.
Just got the car tuned. Car is running on kpro. AEM boost solenoid. Car boost find when you use the commanded boost such as 50% duty cycle. But when you put 50% in say 3rd gear it hits over boost. Does anyone have any suggestions to try. I can adjust the boost through the commanded part. But once I put anything in the gear table it just goes as high as it wants to until it hits boost cut.
Help is appreciated. Dustin
Old Mar 10, 2014 | 04:38 AM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
Default Re: Suggestions on boost table problem.
Sounds like you should find a tuner who actually knows how to tune or pay the amount to have those tables tuned for you. No specs were given for your setup to be able to help you either. Each setup is going to like different things - and you never gave any relevant information about your fixed duty cycle to be able to see what direction you were heading...
Old Mar 10, 2014 | 05:50 AM
30psi_gst's Avatar
What info do you need?
Old Mar 11, 2014 | 01:10 PM
Muckman's Avatar
Moderator in Chief
We need to know how you have the EBC plumbed and how you have it setup in the software.
sh!ft
Jul 8, 2011 07:39 AM
stunnerone23
Sep 1, 2008 03:34 PM
Project X
Jul 17, 2008 08:38 PM
TypeSLO
May 29, 2007 05:12 AM
JrCRXHF
Nov 13, 2003 03:50 AM
