obd2 to odb1 harness question
Old Feb 9, 2014 | 12:14 PM
ktegra17847's Avatar
Default obd2 to odb1 harness question
Hello, I have a question about a my obd2 to obd1 jumper harness. I got to looking around at it and noticed it has a resistor soldered in between pinout 21 ICM1 and pinout 25 IGP1. For what reason would the previous owner have done this? The car is a 2001 Gsr with obd1 ecu. Here is a Picture
Old Feb 9, 2014 | 12:18 PM
EsotericImage's Avatar
Retired Moderator
Default Re: obd2 to odb1 harness question
hmm. would that be an ELD?
Old Feb 11, 2014 | 03:02 PM
VegasInvasion's Avatar
I'm Huge In Japan
I don't think that's the proper way to do that, but I believe it's to fix a tachometer issue that can happen with OBD2B conversions. I would advise removing that and insulating the wires. It looks like the resistor is charred to hell anyway.
Old Feb 15, 2014 | 04:36 PM
Miguel613ekb18c's Avatar
That's the bypass for the immobilizer I think so there should not be a constant check engine light as 2000 to 2001 came with immobilizer
Old Feb 17, 2014 | 06:18 AM
Blown90hatcH's Avatar
It is definitely for the tach issue sometimes found on OBD2b Integras. You get what you pay for; that looks like crap. Depin it, remove the resistor and shrink those wires up.
Old Mar 2, 2014 | 02:07 PM
ok guys thanks for everything I just got back to read all the info! im going with hondatta s300 when i get the money
Old Mar 2, 2014 | 02:08 PM
if i do remove it will I have any issues? It was like this when i bought the car.
Old Mar 11, 2014 | 02:26 PM
I'm Huge In Japan
the immobilizer on obd2b is inside the ecu.
you shouldn't have any issues as long as you insulate the wires.
mindless4banger
Jan 21, 2016 09:33 PM
civic_ekek
Aug 10, 2005 10:14 PM
DGAF
Jul 7, 2005 05:37 AM
