running lean
Old Apr 6, 2009 | 02:49 AM
traxxasx's Avatar
Default running lean
Ok so i thought my car was running really rich due to sluggish and not much power, bad mpg ecu. So we put it on the dyno and come to find out im running really lean. My afr's is like 14.0-14.5. it never used to run like this and just one day it has.
My set up
1991 ef civic odb0 pr3
b16a
intake
header
catback exhaust
gsr cams
Now i was told a 255 fuel pump would fix this problem, since it has an old stock fuel pump right now.
No check engine light all sensors are good. The only thing i do not get is if its running lean why do i have no power and horrible mpg.
car does not smoke at all and idles and runs fine, just no power and lean.
Old Apr 6, 2009 | 04:50 AM
mtber's Avatar
Default Re: running lean
It would be ideal if you had a fuel pressure gauge on the vehicle to determine if you were seeing fuel pressure drop on the dyno.
DawgC2
Mar 10, 2012 12:11 PM
s032105k
11
Apr 14, 2011 08:01 PM
N hatch
18
Apr 16, 2004 11:56 AM
dj_seloe
Oct 15, 2003 07:32 PM
