crome tuning for idle
Old Mar 24, 2009 | 04:34 PM
keving85's Avatar
Default crome tuning for idle
is this is common problem with crome... setting a good idle with a turbo b18b1 stock fpr? 450cc injectors?
Old Mar 25, 2009 | 05:56 AM
Type-GS-R-Turbo's Avatar
Default Re: crome tuning for idle
Not really. I typically add fuel tools and use a .7 multiplier for everything except for TPS additional.
Just let the car warm up all the way and proceed to adjust that number until you get the AF you are looking for. (14.7)
What exactly is it doing? Are you unable to get the AF you need or is the car surging?
Old Mar 25, 2009 | 09:03 AM
keving85's Avatar
Well the tuner can't seem to get it to idle right. It will die when pressing the clutch and idle high then surge. With stock ecu it does like stock
mouastar
Jul 7, 2011 12:21 PM
Hyaboosta
Jul 13, 2005 02:14 PM
Boost2NA
Nov 15, 2003 11:36 PM
Black R
May 14, 2002 11:59 AM
