having issues with crome
Old Apr 28, 2009 | 06:39 AM
si90rex's Avatar
Default having issues with crome
I chipped my p30 and put it in the car. hooked the laptop up and did the setup and detected a connection so i clicked the realtime toolbar hit write and it could not detect the ecu. so i closed the program out and tired it again but this time the progess loaded and said successfull. so i cycled the key and the cel didn't go off. so i tired it 5-6 more times. then decided it was late and stopped for the night. I m not ready to start the vehicle, it has a fresh ls/vtec but i would to start it wed. night. thanks for any help.
Old Apr 28, 2009 | 06:14 PM
si90rex's Avatar
Default Re: having issues with crome
bump
Old Apr 28, 2009 | 06:29 PM
93turbo16's Avatar
Did you try to burn it to a chip and make sure the ecu is working properly?
I would do that before you get into trying to tune it with an ostrich or log from it. That way you know the ecu is chipped properly.
Old Apr 29, 2009 | 10:34 AM
si90rex's Avatar
ok i guess ill have to buy a chip to burn after i tune it. thanks
Old Apr 30, 2009 | 11:37 AM
si90rex's Avatar
i put the ecu in my hatch which has a p28 and a z6 in it. the p30 started the car and reved up. but the cel never goes off after the relay clicks
Old May 2, 2009 | 11:37 AM
si90rex's Avatar
car starts in limp mode
Old May 2, 2009 | 05:47 PM
G2IntegraGS's Avatar
check for codes...
Old May 2, 2009 | 07:09 PM
ashb82's Avatar
did you remove checksum routin
Old May 3, 2009 | 07:52 PM
si90rex's Avatar
no codes at start up cel light was on. check code nothin flashes just solid.
yes i ran check sum.
idk what i did wrong, all my soldering was perfect lookin, and nothin was touching. but there was a black burnt spot on the board, i always worked fine before running the stock program and i desoldered j1 and everything worked fine...... i guess ima start over with a p28.
Staypuff578
Feb 25, 2010 04:23 PM
kentuckyhatch
Engine Management and Tuning
Jun 30, 2009 10:05 AM
Da1spaz247
Mar 19, 2007 07:32 AM
Acura_I-RS
Oct 30, 2005 09:06 AM
