Crome Changes
Old Mar 29, 2009 | 02:47 PM
civic-r11's Avatar
Default Crome Changes
I am using crome on my lsvtec car right now.. and i am wanting to run 93 pump on low boost and i am wanting to run e85 on high boost.. Will crome allow me to do that or i am just going to have to pick which one i am wanting to run..
If you run e85.. do you have to run it all the time in the car or can you run it when you want tooo. Cause that is what i want to do.. run e85 when i want to.. and majority of the time run 93 pump thanks..
Old Mar 29, 2009 | 03:05 PM
93turbo16's Avatar
Default Re: Crome Changes
You could always run a Moates 2-timer and program a 512 chip, which can hold two maps.
Then just program both tunes on 1 chip and then switch between them with the 2-timer.
Old Mar 29, 2009 | 03:29 PM
civic-r11's Avatar
So if i don't run a moates 2 timer.. i can not do that.. cause i really want to run E85 sometimes, to get more power out of the car..
Old Mar 29, 2009 | 03:54 PM
Ls_dx's Avatar
Or you can run an ostrich in the car and upload a diff map .. or burn 2 chips and swap them out quickly with a ZIF socket
Old Mar 29, 2009 | 04:31 PM
civic-r11's Avatar
so i am guessing that.. if i want to run e85.. i am just going to have to get a 2 timer.. or just run s300
Old Mar 29, 2009 | 04:34 PM
civic-r11's Avatar
if i just have to run to chips.. that would be fine with me.. i don't have a issue just swapping out chips when i want to run a certain fuel. would that work..
Old Mar 29, 2009 | 10:09 PM
bunnyx's Avatar
when you chip your ecu with crome set-up. does it automatically make your car run to its spec or do i have to take my car to go tune at a shop? because the closest shop that can tune for me will be about 200 mile from where i live.
Old Mar 30, 2009 | 05:09 AM
civic-r11's Avatar
when you get crome.. you get a base map chip.. and then you have to go get it tuned. the base map is only to get it started.. it is not to just chill on it.. it is a temp chip..
Old Mar 30, 2009 | 05:14 AM
GhostAccord's Avatar
Yes it would work.
How often do you plan on swapping chips?
Probably worth your wile to get an ostrich or a two timer if your looking at swapping frequently. That is unless you plan on leaving your ECU out in the open with the cover off it. IMO It would be APITA to take it out of the bracket, remove the cover and chip every time you want to swap fuel. Not to mention if you break a pin on a chip from pushing and pulling on it too much your SOL unless you carry around a back up chip for each map.
Oh, FYI eCtune has a secondary map feature that you can set up with a switch to run a second map.....
Originally Posted by eCtune.com - Features
Secondary maps(second set of high / low cam maps)
* Selectable with any General Purpose output
* With input switch(normal fuel/e85 fuel/race fuel)
* Based on TPS/RPM/MAP
No it does not automatically set up for your car.
If you have to ask this question, I would say that your best bet would be to buy a base map from a reputable tuner. (Xenocron.com or Phearable.net) They should be able to create and burn you a base map for your particular setup. That should get you the 200 miles to your tuner.
Old Mar 30, 2009 | 06:43 AM
civic-r11's Avatar
Originally Posted by GhostAccord
Yes it would work.
I guess i am going to be running two maps.. but i hope crome will be able let me run two maps.. but what is better and get a ostrich or a two timer.. and what would be easy to install.. and i am hoping my tuner will be able to get it installed for me..
Old Mar 30, 2009 | 07:03 AM
RC000E's Avatar
Wow...it seems like you keep asking the same questions over and over.
Get tuned on E85, get tuned on 93. Either keep two chips and switch them, or run the 2 timer setup. Simple as that.
Be sure you drain ALL E85 before switching to 93 though. Don't run mixes of half tank E85 then fill with 93...you'll run into rich/lean issues.
Old Mar 30, 2009 | 07:16 AM
Crome only allows you to set up & tune for one map at a time. But you can still create two separate .bin files (tuned maps) that you can;
1. Burn 2 separate chips (1 with your 93 .bin and the other with your E85 .bin)
2. Burn them on one Moates two timer chip Or
3. Have two .bin files saved on a laptop/computer that you can upload individually to a Moates ostrich.
*Note: You will have to tune your car twice, once for each fuel setup. (.bin file/map)
What you are asking is possible but it's up to your tuner if he can do it for you or not. Don't go to your tuner hopping he can do something. You should be asking him these questions before you go.
Old Mar 30, 2009 | 09:27 AM
civic-r11's Avatar
I have left my tuner a message.. but he has not got back to me yet.. but i am going try to get this done... i hope this can work.. cause i am just seeing what is up with this.. cause my orginal plan was to tune with water/methonal..
EFn JP
Midwest
223
Apr 15, 2008 12:05 PM
hondaracing1
Jun 6, 2004 03:31 PM
