Ctr ecu
Old Apr 8, 2009 | 02:51 AM
FAmou5's Avatar
Default Ctr ecu
I am looking for the best type of tuning capability for my B16B. I know most of you know that the ECU code is PCT, but I can't find an engine management system for it. Thanks.
Old Apr 8, 2009 | 06:19 AM
GhostAccord's Avatar
Default Re: Ctr ecu
Best
Stand alone EMS = AEM - Haltech - Motech
Convert to OBD1
Cheapest, but still reliable. depending on the tuner
Chipped OBD1 USDM 92-95 Civic/Integra ECU = Hondata S300/200 - eCtune - Neptune RTP - Crome Pro - Uberdata
Available ECU's = PW0 - PR3 - PR4 - P06 - P08J - P28 - P30 - P61 - P72 - P74- P75
Old Apr 8, 2009 | 07:59 AM
FAmou5's Avatar
Default Re: Ctr ecu
okay I know a little about cars but can you break that down to dummy terms? Or here is a try....I have to switch out my ecu with one of the available ones listed in order to use the EMS?
Old Apr 8, 2009 | 08:27 AM
Default Re: Ctr ecu
What make & model car is your JDM B16B in? Do you have an Ek9 Civic Type-R?
Old Apr 8, 2009 | 08:37 AM
FAmou5's Avatar
Default Re: Ctr ecu
no I am running the B16B in a EJ1, 93 EX
Old Apr 8, 2009 | 09:03 AM
Default Re: Ctr ecu
Do you have a P28 ECU in the car right now?
Old Apr 8, 2009 | 04:21 PM
mtber's Avatar
Default Re: Ctr ecu
Read http://www.phearable.net/tech/efibeginnerguide.html
I hope that helps.
Old Apr 8, 2009 | 06:10 PM
FAmou5's Avatar
Default Re: Ctr ecu
That page does help a lot. Thanks. Now I just have to figure which ECU to buy and where to scavange up a jumper harness. Which ECU is recommended by you guys? I have heard bad things about the P72 but neutral things about the chipped P28. This tuning business is a lot of decisions.
Old Apr 8, 2009 | 06:52 PM
mtber's Avatar
Default Re: Ctr ecu
A p72 and p28 will function exactly the same except for the p72 can handle the use of a knock sensor and intake air butterflies if your motor needs these capabilities which most do not.
Old Apr 8, 2009 | 08:45 PM
FAmou5's Avatar
Default Re: Ctr ecu
Well most of this has helped me make up my mind that I will be buying the p28 chipped. After all the motor is still stock and I have many more upgrades that I will be adding to the car. I am going for a build with Skunk2 valves, springs, retainers with the Stage 2 cams and cam gears and intake manifold. In the process of getting port and polish head right now but I am trying to increase the horsepower in everything that I install. Thanks for all of your help guys and when I get started I will let you all know.
Old Apr 9, 2009 | 01:30 AM
Default Re: Ctr ecu
What ECU is in your car right now? From my research the 92-96 Civic Ex came with a P28. Therefore you just saved yourself from having to buy an ECU. You just need to send your P28 to be chipped.
Old Apr 9, 2009 | 01:36 AM
FAmou5's Avatar
Default Re: Ctr ecu
You have a point. I am not near the car due to me being deployed in Iraq, but I will have to find that out. I bought the car with the B16B already swapped in and what I am doing now is collecting parts for it. thanks again
Old Apr 9, 2009 | 03:43 AM
Default Re: Ctr ecu
OK so it may or may not have the P28 in it. I would wait until you get back from your tour to buy an ECU. Verify the one you have first.
Cheers
Old Apr 9, 2009 | 04:28 AM
FAmou5's Avatar
Default Re: Ctr ecu
I will likely have one of my buddies check it out. Thanks again, this thread was very helpful.
HAMOTORSPORTS
Performance
172
Sep 29, 2017 11:00 AM
jaygood2go
Apr 4, 2013 07:58 PM
hondateg10
Mar 25, 2007 03:50 PM
