tuning for 100 octane
Old Apr 6, 2009 | 10:09 AM
4potnick's Avatar
Default tuning for 100 octane
Ok everyone, I need a little help. I want to tune my car for 100 octane. I have tuned it myself so far. Cleaning up afr's is no problem with freelog and free crome. I have never messed with timing. just the simple retard per #. I do want to take advantage of more timing with the 100. Any help of where to start and what kind of egt readings I'm looking for along with anyh other info. I can get 100octane for less than $250 gallon 1mile from my house.
Old Apr 6, 2009 | 04:32 PM
mtber's Avatar
Default Re: tuning for 100 octane
I would suggest renting a dyno to dial in your ignition timing.
Old Apr 7, 2009 | 08:38 AM
4potnick's Avatar
I wish I had money for a dyno, but I don't Probably why I'm running free crome. Can I get away with just retarding a less per psi in the options? maybe I could just retard ignition .50 degrees/lb boost. make a little ore more and have a more consistant fuelo of much better quality? I know how to use all of crome but know very little about ignition timing. Anyone have any good links to help me learn bout timing.
Old Apr 7, 2009 | 12:23 PM
mtber's Avatar
You are not going to learn anything until you spend the money on dyno time & tune the vehicle in a controlled environment.
Old Apr 7, 2009 | 12:28 PM
NeKe1point0's Avatar
Pm'd
Old Apr 7, 2009 | 09:35 PM
4potnick's Avatar
understood, I was hoping I could find a couple people with experience using the 100 to see what worked for them and then take it from there
booboo782
Engine Management and Tuning
Sep 20, 2013 12:05 PM
I CRX I
15
Mar 27, 2009 06:44 PM
jmal1919
Jun 1, 2005 12:39 PM
cnycivic
Jun 25, 2003 09:44 PM
echo999
Dec 31, 2002 11:28 AM
