Limits of the stock ECU?
Old Apr 18, 2009 | 12:09 AM
offcamber's Avatar
Default Limits of the stock ECU?
2000 Integra LS for auto-x and daily driving:
turn down bolted on in place of my axle back muffler (saves ~20 lbs.) The rest of the exhaust is stock. Sounds like an aftermarket muffler.
eBay cold air intake (long tube) with OEM size piping and K&N filter (saves a few lbs.).
not a big desire to leave 87 octane (low grade) gas unless i get big low end torque gains
Is this safe and does it add power on a stock ECU? Can i adjust the timing on the distributor (w/o dyno) to "tune" my car for this? What if i have the distributor tuned on a dyno? I don't want to buy an expensive piggy back(ST class legal). BTW, i have new OEM rotor/cap/plugs and valve adjustment to the bleeding edge (.003/.006). I also reset the ECU by disconnecting the battery so it could learn my setup faster.
What i could do: turn down after the cat. and or DC 4-2-1 header for weight reduction and slight increase in power? would this require a tune, etc.? How much weight would i save going from stock to a DC header?
Feel free to elaborate beyond my particular setup...
Old Apr 18, 2009 | 05:29 AM
mtber's Avatar
Default Re: Limits of the stock ECU?
If your planning on staying at 87 oct. Leave the ecu/distributor alone.
Old Apr 18, 2009 | 07:13 AM
offcamber's Avatar
how much will i gain by going to premium and adjusting the distributor? Can the stock ECU handle a header?
Old Apr 18, 2009 | 11:04 PM
B16Drag's Avatar
Increasing octane will not increase your HP. Please read grasshoppa...
ECU will be fine with the header.
raverx3m
10
Mar 17, 2013 09:57 PM
meheartmycivic
12
Sep 12, 2009 06:26 PM
otacon122
May 26, 2008 12:42 PM
snowboardgeek1
Aug 9, 2006 09:46 PM
[PL]typeR
12
Apr 25, 2005 10:16 AM
