crx tuning
Old Mar 30, 2009 | 08:36 PM
crxnatic's Avatar
Default crx tuning
my tps sensor seems to cause a problem on the engine performance i heard that by adjusting it either to one side or the other affects on the function of it how would i know where to leave it alone in an angle it will provide the right information to the computer to get the proper amount of fuel.
Old Apr 4, 2009 | 12:58 AM
sanimalp's Avatar
$cat /dev/urandom
Default Re: crx tuning
what evidence do you have to show that it is your tps sensor? Is it throwing a CEL? honda tps sensors cant be adjusted, in terms of the sensor itself. You can adjust the idle by messing with a bypass screw on the throttlebody, but im guessing that is not your problem.
You need to provide a lot more information if you want more help..
Old Apr 4, 2009 | 07:31 AM
CW-ITR's Avatar
X2.
What is the problem?
Old Apr 6, 2009 | 02:55 PM
crxnatic's Avatar
is throwing a code. but have replace it several times and it throws a code, i dont see a difference when i disconect the plug. i checked the wiring and dont see anything wrong.
Old Apr 6, 2009 | 04:27 PM
mtber's Avatar
It is very simple. Calibrate the tps signal to be .45 with the throttle shut & 4.5 with the throttle 100% open.
snowboarderbrt
17
Sep 4, 2014 01:42 PM
mikester1222
Aug 19, 2009 01:14 PM
homeskillet
20
Jan 10, 2005 02:28 PM
SIK IN DA HED
Nov 21, 2002 03:21 PM
