Built b16 turbo help!
Old Mar 25, 2009 | 04:44 PM
stalyun's Avatar
Default Built b16 turbo help!
hey, i have a built b16 turbo. ive had several issues with my setup. It has been professionally tuned(not by me).
issue 1- i am going through spark plugs reaaaally fast. I currently have an msd SCI box w/ blaster coil, cap, wires. I was told that my ignition was so hot that im actually burning the gap open in my spark plugs. I installed a new set of plugs 1 week ago at a gap of .022. after 1 week my gap was at .024. the last set of plugs i went through burned from .022 to .028 in 1 month. Im also showing signs of detonation on all pistons. piston 4 is the worst. i was told that the SCI box was most likely the cause of the issues.
issue 2- detonation. would the SCI box be causing my detonation?
thank you
Old Mar 25, 2009 | 04:46 PM
mtber's Avatar
Default Re: Built b16 turbo help!
Hi ?
Old Mar 25, 2009 | 05:11 PM
stalyun's Avatar
sry bout that. i pressed enter after i put hey. its fixed lol
Old Mar 25, 2009 | 07:23 PM
mtber's Avatar
A properly installed msd system is not going to kill your plugs.
What is the motor setup (give all specs)...
What is it tuned on ?
Do you have a wideband oxygen sensor gauge in the car? If not get one...
Old Mar 25, 2009 | 08:34 PM
stalyun's Avatar
b16a2 @ 81.5mm
darton sleeves
eagle rods
cp pistons
titanium valve springs and retainers
cam gears
brian crower stg 2 turbo cams
cosmetic head gasket
TB and IM
t3/t4 50trim @ 22psi
i do have a wideband in my car. under boost im high 10's low 11's
also have oil psg, egt, boost, water temp gauges.
it is tuned on ectune
Old Mar 25, 2009 | 10:35 PM
mtber's Avatar
b16a2 @ 81.5mm
darton sleeves
eagle rods
cp pistons
cam gears
TB and IM
What are your air fuel ratios at idle ?
What model plugs are you running ?
Old Mar 26, 2009 | 06:24 AM
stalyun's Avatar
plugs are ngk 5671a-8 "4554" non projected
a/f at idle is in the low 15's high 14's
at cold start its high 12's low 13's
Old Mar 26, 2009 | 09:52 AM
Ls_dx's Avatar
Everything sounds right on.. what kind of fuel is in the car??
Old Mar 26, 2009 | 10:44 AM
stalyun's Avatar
93octane
under boost my a/f is low 11's high 10's.
Old Mar 26, 2009 | 03:50 PM
Ls_dx's Avatar
Isnt it true, that with a MSD system, you can increase your gap?
Old Mar 26, 2009 | 08:57 PM
stalyun's Avatar
i started out with a gap at .028 and within 1 month i started having misfire issues at high boost becuase the spark was blowing out.
when i pulled the plugs the gap was at .032
Old Mar 29, 2009 | 08:45 PM
supraccordlx's Avatar
MSD are junk, take the crap off and put stock components back on.
Old Apr 1, 2009 | 07:36 AM
stalyun's Avatar
werd
Old Apr 5, 2009 | 06:38 PM
stalyun's Avatar
SCI box is removed. everything is running great.
kte324
Mar 15, 2010 09:36 AM
Boostinb20!
Jul 16, 2009 02:33 PM
1baddcivicsi
Oct 6, 2006 07:35 PM
eg2turbo
Jan 30, 2003 07:38 PM
faygay79
Jan 9, 2003 06:55 PM
