automatic ecus
Old Apr 30, 2009 | 09:31 PM
91integra_rubio's Avatar
Default automatic ecus
is there any use for automatic ecus. can they be chipped and socketed and used in a manual car?
Old May 1, 2009 | 08:11 AM
HRTuning's Avatar
Default Re: automatic ecus
You can remove a resistor to make them manual. They can be chipped and used just like the rest.
Old May 5, 2009 | 05:15 PM
GregHobson's Avatar
Explain. I have a 92 Civic that is Auto but due to mod the AUTO (PM6) ecu does not like it. I need to tune. what can I use and does the damn thin have an TCU like I keep hearing or is that no on the Civics.
Old May 5, 2009 | 11:31 PM
HRTuning's Avatar
PM6 is OBD0 (Pre-OBD), which won't plug into a 92 civic at all.
Old May 8, 2009 | 04:13 PM
GregHobson's Avatar
OK let me ask this again. I DO NOT have a manual nor do I intend on getting it. And the ECU is a P06 sorry. I am changing it to a P28 for an AUTO, and need to make sure I can socket it and tune it with Neptune Crome, etc...
Old May 8, 2009 | 04:30 PM
Bangher4$'s Avatar
you can.
Old May 9, 2009 | 01:24 PM
JDMFreak's Avatar
Can you explain this process? I have P75 LS Ecu OBDIIa. Thank You.
sorry for thread jack
Old May 10, 2009 | 04:31 PM
Bangher4$'s Avatar
obd2 are not the same as a obd1 and cannot be done as easily
turbotime
43
May 5, 2014 04:52 PM
brad22486
Jan 25, 2012 09:46 AM
RamenDA9noodles
Sep 24, 2007 07:30 AM
B18Cej1
Sep 10, 2006 01:39 PM
lilcasino
Oct 4, 2002 02:00 PM
