A few s300 questions.
Old Mar 23, 2009 | 09:25 AM
cvcrcr99's Avatar
Default A few s300 questions.
I picked up a p28 ECU with a Hondata s300 a couple weeks ago. So forgive me if my questions seem noob-ish. I am running a 99 Civic ex d16y8 with crower stage 2 camshaft. I have supertech valve springs/retainers, skunk2 IM, intake, dc header, apexi WS2 exhaust etc. My questions are (I did search and check out FAQ's):
1. Can I use a b16 knock sensor and wire it into the Hondata since the d16 doesnt come with one? If so, what exactly would I have to do?
2. Regarding a wideband, can I use an o2 sensor from a RSX as my wideband? My buddy says that RSX's come with OEM widebands. If not, I'll end up getting a PLX or AEM UEGO.
If anyone can help, I appreciate it!
Old Mar 23, 2009 | 09:43 AM
Ls_dx's Avatar
Default Re: A few s300 questions.
Im pretty sure that your p2p harness (civic ex) should be wired for a stock knock sensor.
and I would recommend the AEM wideband. I dont think that ANY stock vehicles came with a stock wideband.
Old Mar 23, 2009 | 10:06 AM
Spunkster's Avatar
A P28 does not have the circuitry for knock control. To have knock control you would have to install the s300 into a P30, P72 or P61.
Old Mar 23, 2009 | 10:20 AM
cvcrcr99's Avatar
Thanks for the quick replies. I guess I'll bag the knock sensor idea for now since the p28 doesn't support it.
I guess it's time to start searching for a wideband! Thanks again guys!
Old Mar 23, 2009 | 10:45 AM
Spunkster's Avatar
I recommend the PLX widebands, I have 3 cars with one in each and they have been working perfectly now for over 5 years.
Old Mar 23, 2009 | 10:47 PM
alonsobuiltmotors's Avatar
go into parameters and disable knock so u dont get a check light
Old Mar 24, 2009 | 06:45 PM
Garage 808 Hatch's Avatar
the civic VX and i believe HX came with a factory wide band
Old Mar 25, 2009 | 05:27 AM
cvcrcr99's Avatar
Thanks for the info. I will be checking into this. Do you know if can be used with the s300 by chance?
Old Mar 25, 2009 | 05:47 AM
mtber's Avatar
No, it would require a wideband driver.
Old Mar 25, 2009 | 08:13 AM
cvcrcr99's Avatar
How would I obtain a wideband driver, is that on the Hondata site? Would an oem vx/hx wideband + the driver exceed the cost of an AEM Uego gauge/wideband system?
Again, sorry for the noob questions. I appreciate all the info. you guys are giving me!
Old Mar 25, 2009 | 09:24 AM
Spunkster's Avatar
You cannot just use a sensor. You must use a wideband with a wideband controller. PLX Devices sells a complete kit that works great and is the only Wideband that Hondata Recommends.
Old Mar 25, 2009 | 09:47 AM
cvcrcr99's Avatar
Sounds good. Now, off to start saving for a wideband and controller!
Old Mar 25, 2009 | 04:50 PM
mtber's Avatar
Generally they are sold as a kit :-)
CplNet
Engine Management and Tuning
Sep 26, 2010 04:22 PM
Mr.Dew
Aug 18, 2004 11:34 PM
servion
Jul 2, 2004 04:08 PM
brcivic411
Jul 25, 2002 05:57 PM
B19CivicHB
Apr 5, 2002 03:39 PM
