B16?
Old Apr 18, 2009 | 06:12 PM
EGII's Avatar
Icon2 B16?
I recently picked up a b16a Head & block.
My question is how do you tell the differences between heads?.
The original owner wasn't sure which head was mated to the block a 16A or 16A2?
Serial number possibly?
Thanks
Old Apr 18, 2009 | 06:23 PM
filiperuvian's Avatar
Default Re: B16?
hmm...never thought about that one.
Old Apr 18, 2009 | 08:14 PM
jdm602's Avatar
Default Re: B16?
i think theyre the same. only diff between the b16a and the a2 is the compression. other than that, heads are the same. head should prolly be marked pr3. i have an a2 in my garage and its marked pr3-2.
Old Apr 18, 2009 | 09:06 PM
EGII's Avatar
Default Re: B16?
pr3-2.. its yep its marked on the Head.. a2 it is....
So I'm assuming the only benefits if any visually, is its a cleaner head and compression. When i removed the valve cover it looks minty FResh!
Thanks!
Old Apr 19, 2009 | 10:10 PM
JohnnyWash1's Avatar
Default Re: B16?
The only compression differences that I know of are between USDM and JDM b16 motors; 10.2 vs 10.4, respectively. The A2 was simply the OBD2 USDM motor.
skittyscott
10
Dec 8, 2004 04:41 PM
EG617
Dec 5, 2004 12:01 AM
Average Al
Sep 14, 2003 02:41 PM
CrazyKoreanCrx
Jan 29, 2003 12:52 PM
91SiKen
Mar 4, 2002 11:36 AM
