Timing question. Dizzy / ECU relationship
Old Mar 29, 2009 | 07:21 PM
---SPEED-DEMON---'s Avatar
Icon6 Timing question. Dizzy / ECU relationship
Guys just wondering. I was at my tuner shop the other day and my timing was off a little. So it was manually adjusted via the dizzy, no switch was jumped so could the ecu have countered this and re-adjusted the timing??
And if resetting the ECU can change timing what is the need to do it via the dizzy.
And if timing is off, what are the causes for this to happen in the first place??
So my dizzy position is moved a little, so if I reset the ECU will this mess up my ignition??
Its an internally stock B18C1 on stock ECU, just breathing mods done.
Old Mar 29, 2009 | 08:49 PM
HRTuning's Avatar
Default Re: Timing question. Dizzy / ECU relationship
The ECU assumes the distributor timing is sync'd. It doesn't self adjust etc.
Old Mar 30, 2009 | 08:50 AM
Ls_dx's Avatar
Your or your tuner need to sync the dist with the idle timing map. usually at 16.50 with the service connector jumped...
Old Apr 1, 2009 | 12:14 AM
Tony the Tiger's Avatar
Jumping the service connector shouldn't be necessary for ECTune or Neptune for example.. You can lock timing on the software and then sync it up mechanically at the distributor.
JohnnyEF
Feb 10, 2010 06:09 PM
wilsel
Mar 23, 2005 05:37 PM
yeegsr
Oct 19, 2004 10:14 PM
cruzersi99
Jan 29, 2003 09:13 AM
01PYTypeR#1140
Jul 17, 2001 06:33 PM
