some suggestions for s300
Old May 7, 2009 | 04:33 PM
jgraham0326's Avatar
Default some suggestions for s300
Ok, so here is what I need a little help on guys. I am building my boosted B16 at the moment and I was just concerned a little bit about my S300. I have S300 installed in a p28, as most know a P28 does not have a daughter board to read knock. How would you guys suggest tuning the car. Would you suggest getting my S300 re-socketed into a p72 so I have access to a knock sensor or would you suggest tuning off of AFR's? Any advice helps. Thanks guys
-Justin
Old May 7, 2009 | 04:37 PM
Tomdata's Avatar
Default Re: some suggestions for s300
Honda knock sensor are pretty much useless.. Almost nobody uses them anymore. Your best bet is to get the car tuned by a pro. That way you won't have to worry about detonation.
Old May 7, 2009 | 06:01 PM
^ true that anyone have any place they would suggest in the midwest area? I live in indiana.
Old May 14, 2009 | 09:44 AM
duthie14's Avatar
make sure your base timing is good and use a wideband afr to tune
061000rr
Oct 6, 2010 03:30 AM
B18CmeFLYby
Feb 29, 2008 01:12 PM
VTECLuDe96
Dec 22, 2004 09:31 PM
SiHatchTurbo
Oct 11, 2003 10:24 AM
B20-T
Feb 19, 2003 06:39 AM
