GM 3 Bar map wiring problem
Old Apr 6, 2009 | 11:48 AM
TopEndTuner's Avatar
Default GM 3 Bar map wiring problem
Alright I'm in the process of wiring up my GM 3 Bar for my AEM EMS and I've run into a problem. This will be the 5th GM map I've wired up but this hatch is different. Its a 92 Canadian model DX and the Map senor is separate from the rest of the harness, its wired directly to the ECU plugs in its own factory loom. The issue I'm having is that the colors for the Map wiring are not like any of the other 92-95 civics I've done. Rather the a Green/White-ground, white-signal, and yellow/red-5V I have a white, green, and yellow with a green stripe. I'm thinking its like most Honda OBD1 stuff and the white is power, yellow with green stripe is signal, and the green is the ground. Can somebody confirm this for me? And before it starts I've searched and the only thing I've found is the standard wiring which doesn't help me. Thanks for any input
Old Apr 6, 2009 | 12:54 PM
postman's Avatar
Default Re: GM 3 Bar map wiring problem
use a voltmeter to be 100 percent sure.
Old Apr 6, 2009 | 02:58 PM
I thought about that I believe with the GM 3 bar it should read 1.6v between the signal ground right?
Old Apr 6, 2009 | 04:23 PM
mtber's Avatar
Use the wiring information on http://www.phearable.net/tech
Old Apr 6, 2009 | 07:00 PM
Yeah I gues I'm gonna have to do that thanks guys
HatchMo
Oct 12, 2008 04:46 AM
TopEndTuner
Engine Management and Tuning
Oct 4, 2008 04:58 PM
paul93sir
May 31, 2005 03:53 PM
