Setting lamda, a/f with S300
Old Apr 26, 2009 | 08:41 AM
NJIN BUILDR's Avatar
Default Setting lamda, a/f with S300
I've had a S200 in my DD for a few years.I had it working very good.I converted that file to the S300 and it is also driving very good.My problem is getting my NGK wideband to display correctly.It is wired the same way as it was with the S200, into the D14 imput.I am not running a stock o2.I opened up "parameters",go to "closed loop" and set up my voltages.I upload the changes.When I go to display it shows 1.07 a/f at idle while my wb displays 16:1.By changing voltages I can get it to change slightly to .93 or so.If I go to sensors I can see the voltages change in the O2 sensor in the high 3v range.
Is they another place to set up the wideband?
Old Apr 26, 2009 | 09:43 AM
Default Re: Setting lamda, a/f with S300
I figured it out.I just needed to double click on a/f in sensors and change units to a/f from lamda.
Old Apr 26, 2009 | 11:02 AM
93turbo16's Avatar
Yep. Exactly.
Why not run the wideband through D10.. the ELD and remove the two resistors. After its setup, they should read pretty much dead on.
Old Apr 26, 2009 | 07:26 PM
Originally Posted by 93turbo16
Yep. Exactly.
I already had it wired to D14 from when I was using the S200.It worked out fine then ,so I expect it will work fine with the S300.
ACTION JACTION
Engine Management and Tuning
Aug 5, 2015 11:53 AM
crxb16a90
Jan 5, 2010 07:24 AM
eag36
Sep 11, 2005 03:16 AM
J337_UNIT
Apr 19, 2005 03:52 PM
JAW983
Oct 23, 2002 11:55 AM
