Wideband problem
Old Apr 17, 2009 | 05:44 AM
gshatch's Avatar
Default Wideband problem
I own a AEM UEGO. Installed it maybe a 400miles ago.
When cruising with a part throttle the gauge bounces from 14.0 to 15.3. My tuner said it should lock into one or two differant values at constant throttle.
At WOT it only varies from 12.8 to 13. and 14.7ish when idleing.
Old Apr 17, 2009 | 05:04 PM
Tomdata's Avatar
Default Re: Wideband problem
sounds like you have a good closed loop tune in your car (or your car is completely stock)
nothing to worry about
do some research on "closed loop' to learn why it is bouncing at cruise
Old Apr 17, 2009 | 05:23 PM
jdm602's Avatar
on closed loop ecu tries to get 14.7 at part throttle, reading from the o2. thats why it varies from 14-15.
Old Apr 17, 2009 | 05:37 PM
gshatch's Avatar
i'm a big noob
Old Apr 20, 2009 | 05:32 PM
Jim W's Avatar
Yeah thats normal. mine does the same thing.
redsolturbo
Engine Management and Tuning
Sep 1, 2009 02:33 PM
LOGONZOJLS
Jan 29, 2007 02:26 PM
aZnjCC
11
May 23, 2006 01:39 PM
DurboDug93
May 14, 2005 08:01 PM
mrx
Jan 18, 2005 11:48 PM
