Ecu fuse keeps blowing
Old Apr 2, 2009 | 12:20 AM
LOMPSEG's Avatar
Default Ecu fuse keeps blowing
Ive got an eg with a gsr swap tuned on chrome.. the car will idle fine no problem but as soon as i start to drive it it spudders right around 2500 to 3000 and then it blows the ecu fuse under the hood... it does this constantly within 10 seconds of driving....if any 1 is familiar with this symptom plz help
Old Apr 2, 2009 | 11:02 AM
pb16b's Avatar
Default Re: Ecu fuse keeps blowing
was the fuse blowing before the crome? explain more if you want answers... this will tell us if your issue is even related to crome.
Old Apr 2, 2009 | 12:14 PM
mtber's Avatar
An ecu fuse blowing has nothing to do with the engine management on the ecu.
Check your vehicle's wiring & try another ecu.
Old Apr 2, 2009 | 08:52 PM
LOMPSEG's Avatar
I appreciate your guy's help... I fixed it, it was the evap's solenoid positive some how the wire insulation melted and shorted out
94SuperLudeSI
Apr 20, 2008 06:10 AM
civiclxb16a
Dec 23, 2004 02:55 PM
WheAs MaI MojO
Jan 30, 2003 07:49 PM
chuckd05
Nov 6, 2001 08:13 AM
