2 step setup through Nitrous/aux on s300??
Old May 2, 2009 | 12:57 PM
SilverEk3dr's Avatar
Default 2 step setup through Nitrous/aux on s300??
Ok so im kinda sick of hearing the cars bounce off the rev limiter while on the 2 step. I want to know if you can setup the nitrous/aux on a switch to make it 2-step like the way it sounds with motec. Where instead of "bouncing" off the rev limiter it will come on nice and smooth as the turbo starts to spool.
I've tried to actually set it up like motec is, where it retards the timing 100% and wont let the engine past that rpm. The only problem is that with enough pedal it will still defeat the timing retard. No matter how I have it set (tired -999 even) Is there something Im missing? Can it even be done?
thanks in advance.
dirtrdr22CRX
Engine Management and Tuning
Oct 9, 2015 11:39 PM
Cornering Artist
Honda S2000
Mar 18, 2007 03:01 AM
DelSolDon
Jan 24, 2005 06:43 PM
baphomet
Oct 14, 2003 06:58 AM
cliqueSI
Aug 12, 2001 06:38 PM
