getting chipped ecu back to stock?
Old May 13, 2009 | 09:53 PM
scrambled_EG's Avatar
Default getting chipped ecu back to stock?
hi..like the title says..is there a way to get your chipped ecu back to stock? Reason I ask, is because I bought a p28 long time ago and is chipped for a gsr. Don't know name of chip. Anyways I have a d16z6 and would like to get that ecu back to stock. thanks
Old May 14, 2009 | 01:24 AM
RHD_H2b_EG6_Coupe's Avatar
Default Re: getting chipped ecu back to stock?
all you need is someone that has eprom burner. Most shops that have dyno sld be able burn factory map on chipped ecu. That or just find a stock ecu.
Old May 14, 2009 | 04:14 AM
pb16b's Avatar
cut or remove jumper j1 and you're back to stock.
Old May 14, 2009 | 04:16 AM
inspector01's Avatar
Cut the jumper on J1.
Old May 14, 2009 | 07:07 AM
well the chip is a socketed one. sorry noob to chipped ecu's, but can i just remove the chip or is there something that has to be there and i would have to cut the wire to j1. thanks guys
Old May 14, 2009 | 07:13 AM
Cut the jumper to J1 and it won't matter what you do with the socket.
speed_demon018
Jun 4, 2009 02:05 PM
LS stretch
Engine Management and Tuning
Feb 3, 2009 08:40 AM
tubed-ef
May 2, 2007 11:35 AM
