S300 installes -> constant CEL
Old Apr 25, 2009 | 05:55 AM
edm_dc2's Avatar
Default S300 installes -> constant CEL
hello
hello
i have just put a new engine into the car, pulled the hazard fuse and injector plugs to prime the oil system with out any problems.
but when i plugged everything back in to start up and leak check the connections i got a constant CEL when setting the key to position "2", shorted the service connector but no blinks.
the green LED to the right of the USB plug is constant on, but the red on next to it is flashing.
but when i plug in the standard ecu there is no CEL....
car: 1998 euro ITR
engine: 2l LSvtec
ecu: s300 tuned in USA after the engine was assembled and shipped back to me. ecu is fitted with OBD2b connection, OBD2a->2b jumper installed
so there should be a correct map stored in the hondata, but as i read here on the forum it would be a risk for me to connect a laptop with the newest Smanager installed....
is it safe to start? is the ecu in limp mode?
any smart heads out there to help me?
Old Apr 25, 2009 | 06:48 AM
mtber's Avatar
Default Re: S300 installes -> constant CEL
What ecu do you have ?
Did you disable the knock sensor (presuming your ecu does not have a knock board).
Old Apr 25, 2009 | 07:18 AM
edm_dc2's Avatar
dont really remember the ecu name, but it was the original ITR ecu (PR3 maybe?)
the engine was built and tuned by endyn and shipped to me so i really dont have any clue of the map. but no knock sensor installed
Old Apr 25, 2009 | 07:22 AM
mtber's Avatar
There is no such thing as an obd1 itr ecu.
Please check the ecu model number & make sure the knock sensor is disabled if it doesn't have a knock board in the ecu.
Old Apr 25, 2009 | 07:32 AM
edm_dc2's Avatar
no there is a standard OBD2a wiring in the car, but the hondata ECU has OBD2b plug, so there is a conversion harness 2a->2b installed.
knock is disabled
Old Apr 25, 2009 | 10:02 AM
mtber's Avatar
knock is disabled
Do you have a local hondata dealer you can contact to have them inspect the unit ?
Have you tried contacting the dealer you purchased the unit from ?
Old Apr 26, 2009 | 03:15 AM
edm_dc2's Avatar
i dont think there is any approved hondata dealers i norway.
well i bought it from a member on HT so i dont think there is any good aftermarket support :S
but i got a backup on the map so i can try to upload that
Old Apr 26, 2009 | 01:47 PM
Ls_dx's Avatar
Can you check the code??
Old Apr 26, 2009 | 02:47 PM
edm_dc2's Avatar
when shorting the connector the CEL is still constant.
i will try to connect the laptop to the ecu and see if there is any codes indicaed in the Smanager
Old Apr 27, 2009 | 07:48 AM
edm_dc2's Avatar
everything seems fine after uploading a new map into the hondata.
started fine and warmed up on idle.
but to new smaller problems came up. the tachometer in the dash dont work, but hondata and apexi RSM reads it fine.
overheat warning came on, coolant system needs bleeding and try to figure out why the fan did`nt start...
h0nda n00b
Engine Management and Tuning
Feb 27, 2014 09:13 AM
justseeingifitistaken
Nov 22, 2006 06:21 PM
drumminforev
19
Oct 6, 2006 12:12 AM
huntarrr
Jun 29, 2004 09:42 AM
h8tred
Jul 7, 2003 08:35 PM
