checking ecu job
Old Mar 20, 2009 | 06:24 AM
gshatch's Avatar
Default checking ecu job
i need to know how to check the solder on a chipped ecu.
Old Mar 20, 2009 | 07:13 AM
mtber's Avatar
Default Re: checking ecu job
Plug the ecu into a vehicle....
Old Mar 20, 2009 | 07:24 AM
gshatch's Avatar
the ecu doesn't work on two known cars.
i don't smell a burnt board.
i didn't see any blown resistors.
Old Mar 20, 2009 | 07:25 AM
mtber's Avatar
Cut j1 & see if the ecu works. If it does, there is a problem with your soldering.
gshatch's Avatar
your saying i can't pin point one solder
Old Mar 20, 2009 | 07:57 AM
unusual71's Avatar
why are you even asking this? look at the board if everything looks fine but it doesnt work cut J1 like mtber said to return the ecu to stock
Old Mar 20, 2009 | 10:57 AM
gshatch's Avatar
i took out the chip and gave it to my tuner to take some fuel out of it.
it ran fine before now the car is limp mode
Old Mar 20, 2009 | 10:58 AM
gshatch's Avatar
i have hondata S200 and the red light is on constant and the car is in limp mode
Old Mar 20, 2009 | 12:39 PM
GhostAccord's Avatar
Check to make sure you put the chip back in the proper orientation. There should be a half circle marking on one end of chip. That end should be towards the connector side of the ECU. If the orientation is correct have your tuner burn another base map onto the chip. It may not have copied properly to the chip. If it happens again get ask your tuner to fix the problem that you seem to be blaming him for.
Old Mar 20, 2009 | 01:01 PM
gshatch's Avatar
the burn is good and we know that because we put it in a differant ecu.
the last idea is the ecu prongs could have been bent.
Old Mar 20, 2009 | 05:48 PM
supraccordlx's Avatar
Get a dmm.
nick91civicsi
Engine Management and Tuning
Oct 25, 2009 03:27 PM
EFboostedSI
May 8, 2009 02:48 PM
wrXtian
Dec 30, 2004 03:41 PM
5STAR3
Mar 20, 2004 04:40 PM
wrXtian
Apr 13, 2003 04:29 PM
