obd0 ecu flashing code....help
Old Apr 28, 2009 | 04:24 PM
OSR*EF4DOOR's Avatar
Default obd0 ecu flashing code....help
my ecu flashes about 9 times does anybody kno why????????
Old Apr 28, 2009 | 04:42 PM
93turbo16's Avatar
Default Re: obd0 ecu flashing code....help
It is the cylinder position sensor code... It is a sensor in the dizzy.
Old Apr 29, 2009 | 04:01 PM
do you know how to fix it or do i just buy a new dizzy.....an what a dizzy????
Old Apr 29, 2009 | 04:52 PM
CRXB18C1_ALL MOTOR's Avatar
Recently happened to me. Check to make sure you don't have any loose connections in or around that area where the Cylinder Position Sensor is located (inside distributor.)
Otherwise you can check for continuity on the distributor plug terminals/connectors.
Last resort is to replace the distributor with a brand new one which can usually the best way to go. Good luck.
Milby90ls
Sep 10, 2011 09:13 AM
efsedanfan
Oct 22, 2008 07:41 AM
sc00te12d00d
Dec 11, 2003 09:01 AM
TurboLsVtec
Dec 9, 2001 05:04 PM
