s300 and fan control
Old Apr 25, 2009 | 06:24 PM
postman's Avatar
Default s300 and fan control
i have noticed ever since i had my car tuned, that my cooling fan runs constantly. i have searched all through the s300 and can not find anything for fan control options. is this something built right in to the hondata and not changeable or do i have something else going on.
it has not really effected the car in any way. car runs damn near flawless. just thoughtitsould only be on when temps go up.
94 delsol obd1 b16
Old Apr 25, 2009 | 07:41 PM
DB2-R81's Avatar
25 Year Member
Default Re: s300 and fan control
Look under "Parameters", "Protection" Radiator Fan, you are using V1.4.1 (11 March 2009)?
Old Apr 25, 2009 | 09:09 PM
93turbo16's Avatar
Yep. It is definitely under the protections tab under parameters.
Old Apr 26, 2009 | 04:54 AM
postman's Avatar
ahhh. that could be my problem, i havent updated since last summer. since the car is only driven in the summer. was getting ready to freshen up my tune some and figured i might as well get this figured out while im in there. ill do that and check back. thanks
Old May 2, 2009 | 02:09 PM
postman's Avatar
alright, downloaded v 1.4.1. set protection to override fan at 195 degrees fahrenheit. uploaded and the fan still is turning on as soon as the car is fired up. i have only tested this sitting at idle, would that effect anything. ani ideas
Old May 2, 2009 | 02:15 PM
DB2-R81's Avatar
25 Year Member
Bad sensor, relay or wiring, what have you checked?
Old May 2, 2009 | 04:12 PM
red02s2k's Avatar
Most likely you have a short in the wiring so it is always in the closed position.
Old May 2, 2009 | 04:21 PM
postman's Avatar
the fan is stock, i do have the a/c removed from the car. might have to do something with it. i need investigate some more when i get the time.
Old May 3, 2009 | 03:15 PM
postman's Avatar
alright did some more checking over and i have narrowed it down to a problem in tbe pcm. with the ect switch wire disconnected from the pcm the fan operates normally. im not sure which part of the pcm circuit board this runs the fan.i didnt see any burn marks on the board anywhere. any thoughts guys
also figured if i leave the wire disconnected then the s300 control for the fan would be inoperable.
Old May 3, 2009 | 05:36 PM
Evans-Tuning.com's Avatar
Former Vendor
I have your fan turning on constant with the tune. Go under nitrous #1 parameters, under "function" set to disabled. Go to protection and set the minimum operating temp for the radiator fan output. The software did not have a rad fan override feature when I tuned it, so that was the only choice to make it come on sooner than stock. Should have just emailed me, I could have saved you a bunch of hassle.
Old May 3, 2009 | 06:32 PM
postman's Avatar
ahhh. problem fixed. much appreciated
erndog
Honda Civic (2006 - 2015)
Jun 21, 2019 06:43 AM
raidacaipo
16
Mar 29, 2011 08:25 PM
