Chip for a 99 Si? Stock.
Old Mar 31, 2012 | 09:39 PM
Xenon7's Avatar
Default Chip for a 99 Si? Stock.
Is it possible to chip my Canadian 99 SI (American EX)? If so, what are the pro's/con's. I would like it to be a performance chip, not so much mpg. I've seen chips do a lot to different cars like bimmers, volkswagons, and chevy's. Was just wondering how easy/useful it is for a Honda.
Thanks.
Old Mar 31, 2012 | 09:51 PM
GagnarTheUnruly's Avatar
Default Re: Chip for a 99 Si? Stock.
Not worth it. A chip can't get more air into the engine and Honda factory tunes are very good. Best to spend on bolton breather mods and chip later. Air intakes are a good place to start.
Old Mar 31, 2012 | 09:59 PM
Xenon7's Avatar
I have a K&N CAI. Going to put on an after market exhaust soon. Maybe straight pipe depending on if I can find someone that's done it and sounded good.
Any estimate on HP gain or what difference it will make with a Cold air intake?
Old Mar 31, 2012 | 10:30 PM
Bix VT's Avatar
I saw no noticeable power gains when I installed my aftermarket intake (2000 USDM EX). However, it does increase noise by a large amount at WOT. You may net 5whp at most.
Old Apr 1, 2012 | 07:32 PM
mtber's Avatar
You will need modifications such as intake/header/exhaust to really take advantage of an engine computer modification.
You would need an obd2b to obd1 ecu jumper harness & chipped obd1 vtec engine computer. For more information read over http://www.phearable.net/tech/efibeginnerguide.html
Old Apr 2, 2012 | 04:30 AM
Xenon7's Avatar
Say I got the harness, how much of an impact would the chip make? What is a good/reliable place to buy one? Oh, and what's a price range of one.
I don't want a whole tune and all that, that I have to work on myself, I just want a chip that I can plug in, and it works.
Old Apr 2, 2012 | 09:31 AM
Originally Posted by GagnarTheUnruly
Not worth it.
Old Apr 2, 2012 | 10:13 PM
Bix VT's Avatar
Your stock Honda tune is pretty good. You won't make enough power to be worth the cost, at least not without the full range of bolt-ons and/or higher octane fuel. Here is a reliable and reasonably priced place to buy them: http://www.phearable.net/shoppingcart/
You won't find this. All chipped ECUs need to be tuned, and the best way to do it if you don't know how to tune on a dyno is to pay someone to do it for you. This usually costs around $500, or $150-$200/hour on the dyno if you do it yourself. You will also need a wideband oxygen sensor for tuning part throttle on the street, which will run you another ~$200.
99hondacivic
20
Sep 19, 2011 03:52 PM
christianc5692
11
Feb 28, 2010 02:58 PM
tiptopEBPcivc
Mar 17, 2009 08:06 PM
shortlid
Apr 14, 2007 07:14 AM
toadlax
Nov 19, 2001 05:29 AM
