engine swap troubles
Old Feb 13, 2012 | 03:49 PM
Tim Verway's Avatar
Icon6 engine swap troubles
I recently did a mini me swap into 93 civic and it hasnt ran right since. runs fine when its cold but idles rough and dies when its warm. get tps, map sensor, intake air temperature, and idle air control valve codes. i have tried everything to fix them, even put the non vtec harness back in. the intake is from the d15 so i dont understand why all the sensors are tripping when they weerent before. any help?
Old Feb 13, 2012 | 11:23 PM
civickiller's Avatar
Default Re: engine swap troubles
swapped plugs?
tps-map same plug
iacv-iat same plug
JDM EJ2
Jan 11, 2008 01:37 PM
civicmatt
Sep 27, 2003 01:13 PM
