what ecu is this?
Old Mar 25, 2012 | 07:04 PM
Mike_TypeR_EG's Avatar
Default what ecu is this?
Got an extra ecu with my car but not sure what it is.
And maybe how much its worth would help too thanx!
Old Mar 25, 2012 | 07:11 PM
david974's Avatar
Default Re: what ecu is this?
Integra type R ECU, OBD2
mtber's Avatar
That is an obd2a Integra Type-R engine computer
Old Mar 25, 2012 | 07:50 PM
Another ? What would be better p06 with chipped by monotech on basemap or this p73?
I have a Jdm b18c type r.
Old Mar 26, 2012 | 12:33 AM
mouab18c1's Avatar
The chipped ecu if you plan to upgrade down the road. Stock p73 if you plan to keep it stock.
Old Apr 16, 2012 | 04:47 AM
Nitrous1024's Avatar
I have an interesting once for you then. Try identifying this from my 2001 EU1 Civic with the D15B (4 speed automatic)
37820-PLD-J72 What ECU is this and what would be a suitable replacement?
Old Apr 18, 2012 | 08:29 AM
TheShodan's Avatar
Moderator
No.
Old Apr 23, 2012 | 08:39 AM
Ouch
Old Apr 23, 2012 | 09:04 AM
Bix VT's Avatar
Honda ECU list: http://hondaswap.com/reference-mater...cu-list-29129/
also, http://www.hondata.com/techecuid.html
All Honda ECUs have a part number which is located on the side of the ECU and inside the ECU on the connector. e.g. 37820-P72-A01
The part number consists of three components:
Honda's part number for ECU, which is always 37820
Three characters (which are loosely related to the model of car/engine). e.g P72
Three characters (which are the revision of the ECU) e.g. A01 or G52
The middle three characters are the most useful to identify what the ECU is. Different generation ECUs may use the same characters. e.g. a P72 OBD I ECU is different from a P72 OBD II ECU. Here is a list of common ECUs:
The last 3 characters are broken down into 3 parts. "A" generally is used for US ECUs. "G" is European, and "J" is Japanese. There are other versions of this, but you get the idea. The second digit "0" typically means manual transmission, where a "5" means automatic transmission, and the last digit "1" is the version number.
If you plan on leaving the car stock, use a stock ECU.
Old Apr 30, 2012 | 04:22 AM
I've tried Googling it, but I can't find anything for my 37820-PLD-J72 ECU
Old Mar 20, 2013 | 07:11 PM
Is there a list that has anything for the seventh generation civics?
el_ben2
Engine Management and Tuning
Feb 19, 2014 09:10 AM
blown96teggy
Apr 17, 2012 01:40 PM
x4and3r1991
Feb 25, 2008 09:33 AM
Twocs
Apr 2, 2007 07:59 PM
elpiar
Jan 2, 2007 02:24 PM
