Turboedit solid CEL
Old Jan 1, 2012 | 10:26 AM
josephcmiller2's Avatar
Default Turboedit solid CEL
My buddy has an EF DPFI to MPFI conversion using OBD0. I have chipped a PR4 and loaded a stock ROM and the car runs fine. I tried to use Turboedit to modify the stock PR4 ROM and disable the O2. After burning using the exact same process all I get is solid CEL. I re-burned the chip with the stock PR4 program again and everything is fine. What am I doing wrong?
Old Jan 3, 2012 | 02:04 PM
dj211855's Avatar
Default Re: Turboedit solid CEL
Maybe you had put the chipped backwards on the ecu. It sounds like you have no more issue after that.
Old Jan 3, 2012 | 03:46 PM
Nah, that's not it. Double and triple-checked. Works when burning stock map. Doesn't work when burning map with disabled O2.
07Lxcoupe
Engine Management and Tuning
Sep 4, 2011 05:18 AM
Sr420Det
Mar 21, 2010 09:50 PM
Danethomp
Nov 29, 2006 09:28 PM
M.A.R.C.
Mar 20, 2006 07:36 AM
Civicman86
Jan 15, 2005 01:52 AM
